[GRASS-user] Re: Why does g.extension fail...?
Dear all
if you are anxious for a solution right now, the surest way
is to build GRASS from source code, and copy the addon module
into the source tree after building, and `make` by hand.
Oh...I will try and challenge though it seems to be difficult for me the work
I will install 'd.barb' as following.
Is this follow a correct ?
My object is to install addon 'd.barb' into grass6.4.1 binary (already exists.
(1) Obtain source of grass source
svn co svn://svn.debian.org/svn/pkg-grass/packages/grass/trunk/
(2) Obtain source of d.barb
svn co https://svn.osgeo.org/grass/grass-addons/display
(3) extract (2), and copy 'd.barb folder' to /usr/local/src/trunk/display/
(4) cd and sudo su
cd /usr/loacal/src/trunk
(4)configure and make install 'd.barb' only..
./cofigure --target=d.barb
make libs
make MODULE_TOPDIR=/usr/lib/grass64/
It feels sorry also because I am a beginner of linux....
Best
Yasuo shimada ( Japan Weathe Association )
----- Original Message -----
Date: Tue, 28 Jun 2011 10:57:26 +0900 (JST)
To: grass-user@lists.osgeo.org
Subject: Why does g.extension fail...?
Dear grass users
I succeeded in installing d.barb the other day.
Because d.barb was very wonderful addon, I tried installing to other PC.
However, I fail in the installation....
I tried on the following conditions.
(Case 1) ubuntu11.04 wubi version on Windows7
---> Success
(Case 2) ubuntu10.04 vmware version on Windows X
---> failed
(Case 3) lubuntu11.04 vmware version on Windows 7
---> failed
In Case 2 and 3, the same error message is output as follows.
The log might not be read easily for you in a Japanese mode...
--- begin message ---
GRASS 6.4.1 (newLocation_5):/home/shimada > g.extension extension=d.barb
Fetching <d.barb> from GRASS-Addons SVN (be patient)...
A d.barb/legend.c
A d.barb/local_proto.h
A d.barb/main.c
A d.barb/description.html
A d.barb/grid.c
A d.barb/Makefile
A d.barb/points.c
A d.barb/draw.c
U d.barb
リビジョン (revision )46793 をチェックアウト(checkout)しました。
Compiling <d.barb>...
/usr/lib/grass64/include/Make/Grass.make:418: 警告(warning): ターゲット(targe
t
) `/usr/lib/grass64/bin' へのコマンド(command)を置き換えます(replace)
/usr/lib/grass64/include/Make/Grass.make:409: 警告(warning): ターゲット(targe
t
) `/usr/lib/grass64/bin' への古いコマンド(old command)は無視されます(ignore)
make: `/usr/lib/grass64/dist.i486-pc-linux-gnu' に対して行うべき事はありませ
Installing <d.barb>...
You need to enter the root password next to install d.barb:
/usr/lib/grass64/include/Make/Grass.make:418: 警告(waring): ターゲット(targe)
/usr/lib/grass64/include/Make/Grass.make:409: 警告(warning): ターゲット(taget
/usr/bin/install -c /usr/lib/grass64/bin/d.barb /usr/lib/grass64/bin/
/usr/bin/install: `/usr/lib/grass64/bin/d.barb' を stat できません(can not):
N
o such file or directory
make: *** [install] エラー 1 (error 1)
エラー(error): Installation failed, sorry. Please check above error messages
---- end of message ---
I don't understand that though there is '/usr/lib/grass64/bin/', error messeg
e
'can not stat' output..
I tried all cases by user and root(su).
I changed to permission of '/usr/lib/grass64/' from read only to read and wri
t
e . Of course,
I also corrected two make files in all casees;
/usr/lib/grass64/make
Platform.make
Grass.make
http://www.mail-archive.com/grass-user@lists.osgeo.org/msg16723.html
I want you to give profitable information by all means...
Or, please teach other installation method.
Best
Yasuo SHIMADA
