[GRASS-user] Re: Wingrass 6.4 with MSYS does not work
It could be that I have some Cygwin install left over. I also have
python(x,y) installed but don't think that is what is messing with
WinGrass. I will take a look at my path environmental variables and
post an update tomorrow.
Thanks
daniel
On Mon, Jul 5, 2010 at 6:19 PM, Luigi Ponti <quartese@gmail.com> wrote:
...sorry: reposting with a decent subject line...
Dear Daniel,
I have a one-month-old (apologize) wingrass 6.4.svn installed from
http://josef.fsv.cvut.cz/wingrass/ on windows7.
Date: Mon, 5 Jul 2010 17:11:39 -0300
[...] Opening a separate MSys console
and executing /grass/bin/grass64svn will start the Select location
window and after I click on Start, Grass crashes with the following
error:
$ grass64svn
Cleaning up temporary files ...
Starting GRASS ...
ATENÇÃO: Attention!
ATENÇÃO: Locking is not supported on Windows!
          __________ ___ __________ _______________
         / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
        / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
       / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
       \____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS 6.4.0svn (2010)
GRASS homepage: http://grass.osgeo.org/
This version running thru: GNU Bash (Cygwin)
(/usr/bin/bash.exe)
sounds like you are running through Cygwin ("GNU Bash (Cygwin)
(/usr/bin/bash.exe)") -- on my machine the MSys desktop link triggers a
welcome screen that at the same line says "Bourne Shell (/bin/sh)" (and
everything works as expected including the wxpython GUI):
Starting GRASS ...
ATTENZIONE: Attention!
ATTENZIONE: Locking is not supported on Windows!
This version running thru: Bourne Shell (/bin/sh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.4>
Do you by any chance have Cygwin bash.exe on your %PATH% environmental
variable?
As for the Python errors you mention, I am not sure but it may again be a
problem related to %PATH% settings. It is indeed possible to have heritage
Cygwin/GRASS and the new native Wingrass running on the same machine, but
care must be taken to avoid messing with the global %PATH%.
As for running R from GRASS, an approach I have found useful is to follow
the advice by Glynn Clements, i.e. not running GRASS from MSys but instead
use a simple DOS box started via a batch file that sets required
environmental variables to run GRASS, and then call the shell executable
sh.exe (shell scripts designed for Cygwin/GRASS run with minimal adjustments
-- mostly to cope with MSys path conventions issues). Glynn has taken on
this topic in a growing (thanks for your patience, Glynn!) number of posts
-- see for example:
http://osgeo-org.1803224.n2.nabble.com/grass-start-bat-in-windows-tp4492202p4492202.html
Finally, when I have my GRASS-enabled DOS box, I just type R (of course R
needs to be in the %PATH%) and I am pretty much done.
I hope this helps and sorry if I misunderstood your questions,
Luigi
I just installed WinGrass in my home WinXP box and it's working fine.
It also gives me the "Bourne Shell (/bin/sh)" line as reported by
Luigi, instead of the ("GNU Bash (Cygwin) (/usr/bin/bash.exe)") I saw
at my Win7 box. So chances are my Win7 has some left over cygwin
installation and a messed up %PATH%. Will look into that tomorrow
morning.
Cheers and thanks
Daniel
On Mon, Jul 5, 2010 at 8:03 PM, Daniel Victoria
Thanks
daniel
Dear Daniel,
error:
$ grass64svn
Starting GRASS ...
ATENÇÃO: Attention!
(/usr/bin/bash.exe)
Starting GRASS ...
GRASS 6.4>
variable?
-- see for example:
Luigi
I don't see any leftover cygwin instalation in my path. I even tried
removing python(xy) to see if that was the culprit.
Here are some of the environmental variables set in the msys shell
that I believe influences grass:
PATH=.:/usr/local/bin:/mingw/bin:/bin:/c/Windows/system32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/c/Program
Files (x86)/OpenSSH/bin:/c/Windows/System32
WD=C:\PROGRA~2\GRASS-~1\msys\bin\
!C:=C:\Program Files (x86)\GRASS-64-SVN\msys
PART1=C:\PROGRA~2\GRASS-~1\msys\bin\
OLDPWD=/c/Program Files (x86)/GRASS-64-SVN/msys
But I did notice that in the python error that I get, the first error
uses forward slashes (/) and the following lines, the paths have back
slashes (\). Could that be related?
$ Traceback (most recent call last):
  File "c:/Program Files (x86)/GRASS-64-SVN/etc/wxpython/wxgui.py",
line 85, in <module>
    import gui_modules.preferences as preferences
  File "c:\Program Files
(x86)\GRASS-64-SVN\etc\wxpython\gui_modules\preferences.py", line 807,
in <module>
<more errors removed>
Thanks for all your help
Daniel
On Mon, Jul 5, 2010 at 9:59 PM, Daniel Victoria
morning.
Cheers and thanks
Daniel
Thanks
daniel
Dear Daniel,
error:
$ grass64svn
Starting GRASS ...
ATENÇÃO: Attention!
(/usr/bin/bash.exe)
Starting GRASS ...
GRASS 6.4>
variable?
-- see for example:
Luigi
Another thing I just noticed looking at grass64svn script
ArcGIS has set the variable PYTHONPATH=C:\Program Files (x86)\ArcGIS\bin
On Tue, Jul 6, 2010 at 8:54 AM, Daniel Victoria
in <module>
Daniel
morning.
Cheers and thanks
Daniel
Thanks
daniel
Dear Daniel,
error:
$ grass64svn
Starting GRASS ...
ATENÇÃO: Attention!
(/usr/bin/bash.exe)
Starting GRASS ...
GRASS 6.4>
variable?
-- see for example:
Luigi
Dear Daniel,
I don't know, but there seem to be no "PYTHONPATH" string in the my GRASS installation folder.
There is a mingw thing that may be where bash.exe comes from. Why do you need mingw in GRASS MSys? Wingrass has its own copy of MSys, and should not need to point to /mingw/bin or anything else related to unix shell.
Kind regards,
Luigi
I have no idea how mingw got into the path. Can't find it in my system
environment variables. removing it from the path will not change the
GNU Bash (Cygwin) line but now I don't see that bunch of python erros
on screen. All it does is, after I select the location, it will start
grass, tell me that wxvdigit does not work in windows and then gives
me a Goodbye from Grass. The next line shows:
$ Quit wxGUI. Grass is not running.
Could other python installs be messing this up (python 2.4 from ArcGIS)?
Thanks
Daniel
On Tue, Jul 6, 2010 at 10:47 AM, Luigi Ponti <lponti@inbox.com> wrote:
Dear Daniel,
Kind regards,
Luigi
Sorry to revive a very old tread but I just found out why WinGrass was
not working for me so I though I should documment it somehow. I had a
leftover environment variable due to an old Cygwin instal but it was
NOT in the system path... There was a variable called CYGWIN with the
value set to tty. I removed that and now everything works.
Daniel
On Tue, Jul 6, 2010 at 1:05 PM, Daniel Victoria
Thanks
Daniel
Dear Daniel,
Kind regards,
Luigi
