hi Martin,
tried it with the three versions for v.external. None of them worked:
(Sat Feb 04 21:24:43 2012)
*v.external -f *
Sorry, <f> is not a valid flag
ERROR: Required parameter <dsn> not set:
(OGR datasource name. Examples:
ESRI Shapefile: directory containing
shapefiles
MapInfo File: directory containing mapinfo
files)
Description:
Creates a new vector as a read-only link to OGR layer.
Available drivers: ESRI Shapefile,MapInfo File,UK .NTF,SDTS
,TIGER,S57,DGN,VRT,REC,Memory,BNA,CSV,NAS,GML,GPX,KML,GeoJSO
N,Interlis 1,Interlis 2,GMT,SQLite,ODBC,PGeo,MSSQLSpatial,OG
DI,PostgreSQL,MySQL,PCIDSK,XPlane,AVCBin,AVCE00,DXF,Geoconce
pt,GeoRSS,GPSTrackMaker,VFK,PGDump,GPSBabel,SUA,OpenAir,PDS,
WFS,HTF,AeronavFAA
Keywords:
vector
Usage:
v.external dsn=string [output=name] [layer=string]
[--overwrite]
[--verbose] [--quiet]
Flags:
--o Allow output files to overwrite existing files
--v Verbose module output
--q Quiet module output
Parameters:
dsn OGR datasource name. Examples:
(Sat Feb 04 21:24:43 2012) Command finished (0 sec)
____________________________________________
(Sat Feb 04 21:25:36 2012)
*v.external dsn=Testdatenbank -l *
Sorry, <l> is not a valid flag
Description:
WFS,HTF,AeronavFAA
Keywords:
vector
Usage:
[--overwrite]
Flags:
Parameters:
(Sat Feb 04 21:25:37 2012) Command finished (0 sec)
(Sat Feb 04 21:27:11 2012)
*v.external dsn=ODBC:Testdatenbank -l*
Description:
WFS,HTF,AeronavFAA
Keywords:
vector
Usage:
[--overwrite]
Flags:
Parameters:
shapefiles
(Sat Feb 04 21:27:12 2012) Command finished (0 sec)
regards, Christine
View this message in context: http://osgeo-org.1560.n6.nabble.com/Re-winGrass-ODBC-and-MS-Access-database-tp4356636p4365435.html
