On Feb 24, 2008, at 4:30 PM, grass-user-request@lists.osgeo.org wrote:
Date: Mon, 25 Feb 2008 00:30:08 +0100
Subject: [GRASS-user] wxpython gui: error while loding avevry first
layer
To: grassuser <grass-user@lists.osgeo.org>
Message-ID:
<e12429640802241530j7f95c092l86e5884f94fbb423@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1Hi,
I'm playing with the new gui. I've tried it yesterday for the first
time: it rocks!
There are some warning and little errors the come raised with some
tasks, but everything seems to work fine.
The first error I've experimented is:
Can you provide some additional information?
What platform are you using?
What version of GRASS are you using?
23:57:44: Can not enumerate files in directory
'/home/giova/.kde/share/mimelnk/text' (error 13: Permesso negato)
23:57:46: Can not enumerate files in directory
'/home/giova/.local/share/applications' (error 13: Permesso negato)It happens when I launch d.vect or d.rast the very first time. I click
ok and the d.vect (d.rast) window opens correctly. The subsequent
times I do it, it doesn't happen...
What do you mean by "launch d.vect or d.rast"? Do you mean add a raster or vector layer to the layer tree? Or are you trying to launch d.vect from the command line?
Great work!
Thanks
Michael
Giovanni
