How would one read the vector maps in a current mapset into a file, or a list in an array (using python)? If I do ‘g.list vect > walker.list’, the list is not in one column and seems to be separated by tabs, with 4 columns and a bunch of rows of vector files. Would a simple solution be to begin processing that redirected output?
As background…
After running the r.sim.water module, I get a bunch of walkerXXXX vector maps as outputs for given intervals. Works well thus far.
I’m building an animated GIF of the walkers over time, on a shaded DEM. The method I am using is tedious and am seeking to automate the process. I load all the layers (shaded DEM, walkers at various intervals) and turn on one walker vector, and output a .png from the display monitor. Wash, rinse, repeat until all walkers have been captured as an image, then animate them with the ‘convert’ command.
If anyone has some suggestions on how to get vector maps into a list, please let me know. Also, if there is a better way to solve this problem, any feedback would be greatly appreciated.
As background…
If I do 'g.list vect > walker.list', the list is not in one
g.mlist
I'm building an animated GIF of the walkers over time,
an image, then animate them with the 'convert'
command.
g.mlist
command.
g.mlist
command.
