[GRASS-user] reclassed raster no longer showing up
I have reclassed a raster with the rules
1=115
2=115
and it no longer shows up... qgis will display the raster, but not in grass. Is there a color table that I should use? Or some other problem?
Stephen Sefick
Auburn University
Biological Sciences
331 Funchess Hall
Auburn, Alabama
36849
sas0025@auburn.edu
http://www.auburn.edu/~sas0025
Let's not spend our time and resources thinking about things that are so little or so large that all they really do for us is puff us up and make us feel like gods. We are mammals, and have not exhausted the annoying little problems of being mammals.
                                 -K. Mullis
"A big computer, a complex algorithm and a long time does not equal science."
                               -Robert Gentleman
1=115
2=115
grass.
That is weird! Usually it is Quantum that doesn't read, for whatsoever might
be the reason, some GRASS raster color tables.
You did check the classics, right?
- g.region rast=YourMap
- range of both the base- & the reclassed maps (r.info -r)
- remove color rules (-r) and re-assign?
What is the name of your map? Can you find the corresponding color rules file
(inside the "colr" directory?)? What does it contain?
Best, Nikos
