which version/installer would you recommend for a GRASS GIS (newcommer) under
Windows?
Someone is facing a show-stopper -- in his words:
" When I try to install new addons (for instance the denoise one) simply by
clicking the “fetch” button I get this:" (screenshot at)
<http://ScrnSht.com/barbve>\.
I confirm the error message with osgeo4w-wingrass6.4.3RC2 and
osgeo4w-wingrass6.4.3svn please report it as bug.
generation of `modules` file is apparently broken on server side (will
take a look). Anyway you can install an extension from wxGUI command
line by running (note .py extension)
in r54732 `g.extension` should be now more resistant. If `modules.xml`
file is not available or broken, the module try to scan SVN directly
(which is much more slow, no description or keywords fetched).
Martin Landa:
g.extension.py ext=<name of extension>
Thank you Helmut, Martin. I am forwarding this as is.
