[GRASS-user] Reconnecting vector attribution with Postgres/PostGIS
Hi Grass 7 users.
I am trying to connect some vector layers with thier respective attribute tables in postgres/postgis. The tables all connected under version 6.4.4 but not since upgrading to version 7RC1 (on winxp in this instance) they do not. It looks like Grass cannot find the database password but it is present in ‘db.login’. Has anyone else had this happen? Here are the outputs:-
Grass Command Prompt
Cleaning up temporary files…
Starting GRASS GIS…
ERROR: Location not found
WARNING: Concurrent mapset locking is not supported on Windows
/ ____/ __ / | / ___/ ___/ / ____/ _/ ___/
/ / / // / /| | _ \ \ / / __ / / _ \
/ // / , / ___ |/ /__/ / / /_/ // / ___/ /
_// |// |/// _///___/
Welcome to GRASS 7.0.0RC1
GRASS homepage: http://grass.osgeo.org
This version running through: Command Shell (C:\WINDOWS\system32\cmd.
exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching GUI in the background, please wait…
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
H:>DBMI-PostgreSQL driver error:
Unknown option in database definition for PostgreSQL: dbname=postgis
GRASS_INFO_WARNING(2500,1): Unable to open database <host=gisdb.neath-porttalbot
.gov.uk, dbname=postgis> by driver
GRASS_INFO_END(2500,1)
GRASS_INFO_WARNING(2500,2): Unable open database <host=gisdb.neath-porttalbot.go
GRASS_INFO_END(2500,2)
GRASS_INFO_ERROR(2500,3): Unable to open database <host=gisdb.neath-porttalbot.g
GRASS_INFO_END(2500,3)
GRASS_INFO_WARNING(4928,1): Unable to open database <host=gisdb.neath-porttalbot
GRASS_INFO_END(4928,1)
GRASS_INFO_WARNING(4928,2): Unable open database <host=gisdb.neath-porttalbot.go
GRASS_INFO_END(4928,2)
GRASS_INFO_ERROR(4928,3): Unable to open database <host=gisdb.neath-porttalbot.g
GRASS_INFO_END(4928,3)
GRASS_INFO_WARNING(3988,1): Unable to open database <host=gisdb.neath-porttalbot
GRASS_INFO_END(3988,1)
GRASS_INFO_WARNING(3988,2): Unable open database <host=gisdb.neath-porttalbot.go
GRASS_INFO_END(3988,2)
GRASS_INFO_ERROR(3988,3): Unable to open database <host=gisdb.neath-porttalbot.g
GRASS_INFO_END(3988,3)
GRASS_INFO_WARNING(4156,1): Unable to open database <host=gisdb.neath-porttalbot
GRASS_INFO_END(4156,1)
GRASS_INFO_WARNING(4156,2): Unable open database <host=gisdb.neath-porttalbot.go
GRASS_INFO_END(4156,2)
GRASS_INFO_ERROR(4156,3): Unable to open database <host=gisdb.neath-porttalbot.g
GRASS_INFO_END(4156,3)
GRASS_INFO_WARNING(4520,1): Unable to open database <host=gisdb.neath-porttalbot
GRASS_INFO_END(4520,1)
GRASS_INFO_WARNING(4520,2): Unable open database <host=gisdb.neath-porttalbot.go
GRASS_INFO_END(4520,2)
GRASS_INFO_ERROR(4520,3): Unable to open database <host=gisdb.neath-porttalbot.g
GRASS_INFO_END(4520,3)
GRASS_INFO_WARNING(5048,1): Unable to open database <host=gisdb.neath-porttalbot
GRASS_INFO_END(5048,1)
GRASS_INFO_WARNING(5048,2): Unable open database <host=gisdb.neath-porttalbot.go
GRASS_INFO_END(5048,2)
GRASS_INFO_ERROR(5048,3): Unable to open database <host=gisdb.neath-porttalbot.g
GRASS_INFO_END(5048,3)
GRASS_INFO_WARNING(5884,1): Unable to open database <host=gisdb.neath-porttalbot
GRASS_INFO_END(5884,1)
GRASS_INFO_WARNING(5884,2): Unable open database <host=gisdb.neath-porttalbot.go
GRASS_INFO_END(5884,2)
GRASS_INFO_ERROR(5884,3): Unable to open database <host=gisdb.neath-porttalbot.g
GRASS_INFO_END(5884,3)
Paul J. Shapley MSc CGeog (GIS) FRGS
On 02/02/15 13:37, Paul Shapley wrote:
Hi Grass 7 users.
password but it is present in 'db.login'. Has anyone else had this
Apparently there was a change in the db driver that has the effect of not allowing whitespace between the different connection parameters.
GRASS64:
db.connect driver=pg database="dbname=nc_grass,host=localhost" db.tables -p
=> OK
db.connect driver=pg database="dbname=nc_grass, host=localhost"
db.tables -p
=> OK
trunk (7.1):
db.tables -p
=> OK
db.tables -p
=>Error
I don't know if this was intended. Please file a bug report.
Moritz
On Mon, Feb 2, 2015 at 1:57 PM, Moritz Lennert
Hi Grass 7 users.
GRASS64:
=> OK
db.tables -p
=> OK
trunk (7.1):
db.tables -p
=> OK
db.tables -p
=>Error
Not intended. Please try trunk r64396 (update of db/drivers).
Markus M
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
Hi Grass 7 users.
GRASS64:
=> OK
db.tables -p
=> OK
trunk (7.1):
db.tables -p
=> OK
db.tables -p
=>Error
Works now. Thanks a lot !
Moritz
