Hello GRASS users!
I am working to make a certain vector process faster and more effective and would like to ask you for some advice on how to proceed.
I have a vector map containing points and a collection of vector maps containing polygons. My task is to calculate the area covered by these polygons en each polygon map but only under buffers of certain sizes around each of the points. I understand how to do this. My problem is how to do it faster and more effectively.
Each polygon map contains around 2 million of them. The point map has only ~60 points. Both cover the entire country (Sweden). The buffer zones extend only a relatively small area around each point (up to some tens of km). Selecting points and generating buffers around them is easy and fast. The problem appears in the overlay operation. The vast majority of polygons are not involved in the computations but both v.clip and v.overlay seem to need to process them all. This takes a long time.
I wish there could be a way of limiting the number of features involved in the computation to the size of each buffer zone in order to cut down the processing time. I understand (and confirmed empirically!) that setting the computational region does not work for vector operations in GRASS (except for v.in.region). I therefore wonder what can be done in this respect.
I am not new to GRASS but have not used it for heavy duty tasks in a long time, my skills have become rusty! Any hint will be greatly appreciated!
Thanks in advance!
Hernán
