I built a model with a lot of actions and at some point I moved one of the actions out of the visible canvas. I pressed Redraw Model Canvas to be able to select it and move it closer to the others,but the window didnt resize. I tried to use the scroll bars but I couldnt. Now I cant click or select the action that is “out of the visible” window.
Is there something wrong with the graphical modeler window or am I missing something?
Im using GRASS 6.4.2 RC1 and GRASS 7 svn under Windows 7 64 bit. Under LInux Ubuntu everything works fine.
(Also: If I select parametrize in any action and the press Run, the model doesnt run. Nothing happens when I press it)
2011/11/6 Filipe Silva Dias <filipesdias@gmail.com>:
action that is "out of the visible" window.
something?
there were quite a lot of changes in the modeler since 6.4.2RC1, could
you try GRASS 6.5 [1]?
something?
something?
