Date: December 01, 2014
I am a new Grass user and am trying to use it (through the windows GUI) for OBIA analyses - following the method described by Mr. Lennart in his shell script:
http://lists.osgeo.org/pipermail/grass-dev/2013-October/066181.html
Problem history: I am stranded at the last step (which requires usage of v.class.mlpy add-on extension). I asked the question before and got some lead from Mr. Nikos and Mr. Pietro (thanks again!) - install Scikit-learn library and so on. I installed all the associated libraries. However, I could not solve the problem due to my limited knowledge of Python.
Current Problem: Sorry to ask for help again but I think the problem has morphed. Upon re installation of Grass 7.0 and 7.1 and the add-ons, the earlier error messages no longer appear (I am assuming some modifications were made). The latest error messages upon attempt to run the add-on references some files in the grass installation. I am attaching the error message for your reference.
I’ll appreciate it if anyone can explain the troubleshooting process in a step by step method (preferably with some screenshots, assuming the instructed person has no previous knowledge of Python or grass file architecture. My trainees and I are predominantly civil engineering graduates - with basic coding knowledge but zero exposure in python).
With kind regards,
Imtiaz
(attachments)
7.0_v.class.ml_Errormsg.txt (807 Bytes)
7.1_v.class.mlpy_Errormsg.txt (691 Bytes)
