Hello,
How can I select layers in the wxGUI when using CTRL+shift+L that does not contain a specific string ?
Thank you for your help.
Frank
Hello,
Frank
It’s using Python regular expressions, so after some googling, something like this seems to work:
^(?:(?!string).)*$
Seems rather complicated, maybe you can find a simpler solution…
Anna
On Wed, Nov 30, 2022 at 3:25 AM Frank David <frank.david@geophom.fr> wrote:
Hello,
Frank
grass-user mailing list
grass-user@lists.osgeo.org
Hi Anna,
Thank you for the trick !
By the way, do you know how to do with g.list -e rast pattern=… ?
Frank
^(?:(?!string).)*$Seems rather complicated, maybe you can find a simpler solution…
Anna
Hello,
Frank
