Greetings
I have a very “dumb” question regarding region definition/processing:
- I have defined a an area (example; 30N 20S -10W -5W). I have a raster image with (30N 15N -7W -5) I mean, it only cover a part of the region. If I run GRASS image-processing algorithms and processors does it run in all image or only where I have a raster image?
Thanks and sorry for tyhis such a dumb question
Kim
I get a little confused with the region raster processing stuff also.
But, this is what I do, and it seems to work. Anything that is
brought in from the outside (r.in.*) will import the entire map.
Anything that is done withing GRASS will respect the region. So, just
make sure to set the region before each calculation and you should be
OK.
On Mon, Sep 27, 2010 at 8:52 AM, Kim Besson <kimbesson1981@gmail.com> wrote:
Greetings
I have a very "dumb" question regarding region definition/processing:
Kim
grass-user mailing list
grass-user@lists.osgeo.org
Stephen Sefick
____________________________________
| Auburn University |
| Department of Biological Sciences |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
|___________________________________|
| sas0025@auburn.edu |
| http://www.auburn.edu/~sas0025 |
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
\-K\. Mullis
"A big computer, a complex algorithm and a long time does not equal science."
\-Robert Gentleman
Hi stephen and rest of GRASS users
That was not my quiestion. My question is: if a have a an uimage inside a regions, will it process and run for all the region or only for where I have the image(it’s not importing only image-processing). ?
Thanks
Kim
2010/9/27 stephen sefick <ssefick@gmail.com>
OK.
Greetings
Kim
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
Let’s not spend our time and resources thinking about things that are
-K. Mullis
“A big computer, a complex algorithm and a long time does not equal science.”
-Robert Gentleman
Where you don't have the image, if I understand you correctly, would
be NULL values? In that case you will have to default to someone more
experienced, but I suspect that it is run on the entire map, but NULL
means no data so no process. Just a wag.
hth
Stephen
the image(it's not importing only image-processing). ?
Thanks
Kim
OK.
wrote:
> Greetings
> If I
> Kim
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
\-K\. Mullis
science."
\-Robert Gentleman
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
\-K\. Mullis
\-Robert Gentleman
Hi
Ok about this I just need to have an idea (or a link that can explain me this):
1- When I import a raster map (r.in.gdal) will it import all the raster or only the portion that fits in the current defined region?
2- If I define as a region a wider area than the image, will it process where the image is not available?
Thanks
Kim
Where you don’t have the image, if I understand you correctly, would
hth
Stephen
Thanks
Kim
OK.
wrote:
Greetings
If I
Kim
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
-K. Mullis
science.”
-Robert Gentleman
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
-K. Mullis
-Robert Gentleman
This thread in the archives may answer your questions.
http://osgeo-org.1803224.n2.nabble.com/Import-question-td5551110.html#a5558429
HTH,
Stephen Sefick
On Tue, Sep 28, 2010 at 8:17 AM, Kim Besson <kimbesson1981@gmail.com> wrote:
Hi
this):
Thanks
Kim
hth
Stephen
> a
> have
> Thanks
> Kim
>> OK.
>> wrote:
>> > Greetings
>> > raster
>> > region.
>> > If I
>> > all
>> > Kim
>> > _______________________________________________
>> Stephen Sefick
>> | Auburn University |
>> | 331 Funchess Hall |
>> | Auburn, Alabama |
>> | 36849 |
>> -K. Mullis
>> science."
>> -Robert Gentleman
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
\-K\. Mullis
science."
\-Robert Gentleman
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
\-K\. Mullis
\-Robert Gentleman
