Hello,
at the moment I am connecting to the sqlite database with the use of a absolute path in a pythonscript like:
database = sqlite3.connect('/users/Johannes Radinger/Documents/GRASS-GIS/Treene_location/Treene/sqlite.db')
db = database.cursor()
I think it should be possible to set a relative Path in pyton like
database = sqlite3.connect('$relative/$path/$to/$location/sqlite.db') but how can that be done?
It is just because I want to use my script in different location and don't want to change the path each time.
/johannes
On Thu, May 12, 2011 at 1:46 PM, Johannes Radinger <jradinger@gmx.at> wrote:
Hello,
I think that the variable GISDBASE should work. There may be a Python
function to
read it.
import grass.script as grass
import os.path
env = grass.gisenv()
gisdbase = env['GISDBASE']
location = env['LOCATION_NAME']
mapset = env['MAPSET']
path = os.path.join(gisdbase, location, mapset, 'sqlite.db')
On Sat, May 14, 2011 at 2:50 AM, Glynn Clements
import grass\.script as grass
import os\.path
env = grass\.gisenv\(\)
gisdbase = env\['GISDBASE'\]
location = env\['LOCATION\_NAME'\]
mapset = env\['MAPSET'\]
path = os\.path\.join\(gisdbase, location, mapset, 'sqlite\.db'\)
Added to
http://grass.osgeo.org/wiki/GRASS_and_Python#Path_to_GISDBASE
Am 14.05.2011 um 08:32 schrieb Markus Neteler:
import os.path
Added to
Thank you for adding it to the wiki, I think that can be useful for a lot other people.
Just two related questions:
1) I think it is not possible but I just want to ask: Can that method be anyhow used also for the
g.parser options? I tried:
#%Option
#% key: PS_map
#% type: string
#% required: no
#% multiple: no
#% key_desc: name
#% description: Name for PostScript output file
#% gisprompt: new_file,file,output
#% guisection: Optional
#% answer: os.path.join(gisdbase, location, mapset, 'PS_map_result')
#%end
But for sure this is just a string and therefore doesn't work. But is it somehow possible to use
relative information about the path to a file in the answer-option for g.parser?
2) How can I get the path to the script-file i am running at the moment in GRASS? like ./././GRASS/6.5/Modules/bin/script.py? This should work on every operating system.
/johannes
grass-user mailing list
grass-user@lists.osgeo.org
#%Option
#% key: PS_map
#% type: string
#% required: no
#% multiple: no
#% key_desc: name
#%end
No. Even when it's possible (i.e. in C modules), dynamically setting
defaults is a bad idea, as the option information is used to generate
the documentation.
Instead, I would suggest allowing GRASS variables to appear in the
option value, and expanding them at run-time, e.g.:
#% answer: $GISDBASE/$LOCATION_NAME/$MAPSET/PS_map_result
import string
import os.path
def main():
PS_map = string.Template(options['PS_map']).substitute(grass.gisenv())
PS_map = os.path.normpath(PS_map)
BTW: option names shouldn't contain upper-case letters (r.terraflow's
STREAM_DIR= is a bug which wasn't caught until it was too late to
change). 7.x won't recognise option names containing upper-case
letters.
import os.path
print os.path.abspath(__file__)
