Lawrence Houston wrote:
While running Sessions Remotely using NX (www.NoMachine.com) I can have
problems using GRASS's XDRIVER: With NX 2.1 the XDRIVER successfully
displays Raster Images, although with NX 3.X the XDRIVER Window remains
"Blank" without the Raster Image being "Visible"!!! Would prefer to use
newer versions of NX, although without being able to view Raster Images
within GRASS that is not really an "Option"... Is there a "Solution" for
GRASS Users using NX 3.X???
I can replicate the strange behaviour with d.mon when I use bitmap
compression in NX. Selecting the option "Use plain X bitmaps" in the
nxclient works for me. I hope it works for you too
Craig
