[GRASS-user] removal of duplicate points
I have some "squares" which are stored as polygons. When converting these to
points (v.to.points) I am left with the 5 points (first and last point are
duplicated) that define the corners of the "square".
Is there a vector module (v.edit / v.clean) that could remove duplicate
points? I would like to replace the manual operation with v.digit with
something that can be scripted. Note that there are multiple "squares", so a
simple v.out.ascii | head -4 | v.in.ascii would be a little awkward.
Ideas?
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
What’s wrong with v.out.ascii? Couldn’t you export and then remove duplicate points by checking the coordinates? To avoid checking both X and Y, these could be summed, so a single check would be enough.
giovanni
2008/3/5, Dylan Beaudette <dylan.beaudette@gmail.com>:
I have some “squares” which are stored as polygons. When converting these to
duplicated) that define the corners of the “square”.
something that can be scripted. Note that there are multiple “squares”, so a
Ideas?
Dylan Beaudette
530.754.7341
grass-user mailing list
grass-user@lists.osgeo.org
On Wed, 2008-03-05 at 09:58 -0800, Dylan Beaudette wrote:
Hi Dylan
Ideas?
Not really a solution but maybe...
If polygons have first and last points duplicated what happens if they
are converted in polylines?
Duplicate coordinates still there?
If not it could be an easy method to convert boundaries to lines and
continue your task.
maybe a script to remove each fifth line of the ascii?
carlos
On Wed, Mar 5, 2008 at 3:27 PM, Nikos Alexandris
> Hi,
Hi Dylan
> Ideas?
continue your task.
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
> Hi,
> Ideas?
Bad Idea afterall!
On Wednesday 05 March 2008, G. Allegri wrote:
What's wrong with v.out.ascii? Couldn't you export and then remove
giovanni
I guess v.out.ascii | v.in.ascii isn't so bad afterall. I was hoping for a
more general approach that didn't involve the loss of the associated
attribute table. In this case, I only need a simple ID, so the final
incantation looked something like:
v.to.points -v -i in=blocks_1 out=b1p dmax=75 --o
v.to.points -v -i in=blocks_2 out=b2p dmax=75 --o
# patch them together:
v.patch in=b1p,b2p out=vp --o
v.build vp
# remove duplicate points
# new file does not have an attribute table
v.out.ascii vp | sort -g | uniq | v.in.ascii -t out=veg_points
# add attribute table:
v.db.addtable veg_points
# cleanup
g.remove vect=b1p,b2p,vp
# export to shapefile:
v.out.ogr -e in=veg_points type=point dsn=veg_points.shp
And this got the job done. I wonder how hard it would be to add a similar
functionality to v.edit-- which would preserve the attribute table.
Dylan
> Hi,
> to
> are duplicated) that define the corners of the "square".
> so a
> Ideas?
> Dylan Beaudette
> 530.754.7341
Dylan Beaudette
530.754.7341
What about rmdupl for points based on x,y,z?
On Wednesday 05 March 2008, Nikos Alexandris wrote:
rmdupl
right -- from v.clean . This works, but it would be a good idea at some point
to change the v.clean tool descriptions from referring to "lines" when the
tool equally applies to points.
Thanks!
Dylan
Dylan Beaudette
530.754.7341
There so many things to learn! :slight_smile:
Thanks Nikos, I didn't know it too.
giovanni
> rmdupl
Wait a sec,
does it really work? I didn't test it.
It was just an idea: if it works on lines why not on points I thought.
Thanks!
Dylan
Thank you,
Nikos
> > rmdupl
> point to change the v.clean tool descriptions from referring to "lines"
> when the tool equally applies to points.
Wait a sec,
Yes it does work, I just tested it.
Dylan
Dylan Beaudette
530.754.7341
