Dear list,
I got a problem as I'm trying to remove small areas of a vector layer
using v.clean with the rmarea tool: some of these small areas that are
on the boundary of the layer are getting erased rather than being
merged with the closest polygon.
Is that an expected behaviour?
Pierre
Scientist
Landcare Research, New Zealand
On Fri, Sep 16, 2011 at 6:28 AM, Pierre Roudier
<pierre.roudier@gmail.com> wrote:
Dear list,
No, they should always be merged with a neighbouring area along the
shared boundary. Areas are supposed to be erased only if they are
isolated, i.e. do not share a boundary with another area. What GRASS
version are you using? There was a bug which was fixed 2 years ago.
Markus M
Markus,
Sorry for this late reply as I was away from keyboard the last few days,
I encountered this problem while testing the latest grass_svn (grass
7). I can give it a shot using a stable version if you want,
Pierre
2011/9/17 Markus Metz <markus.metz.giswork@googlemail.com>:
Dear list,
Markus M
Scientist
On Wed, Sep 21, 2011 at 12:51 AM, Pierre Roudier
Markus,
You can try, but I would be surprised if the result is any different.
Can you make the vector available for testing, or can you reproduce
this with a vector of the sample datasets?
Markus M
Dear list,
Markus M
Scientist
Thanks Markus,
Here's an archive containing the input vector layer, along with
v.clean output:
https://df.bestgrid.org/quickshare/fb0bb3af778c8a03/vectors.tar.gz
Here's the result of v.info -h on the output:
COMMAND: r.to.vect input="c_means" output="foo" feature="area"
GISDBASE: /data/GRASSDATA
LOCATION: NZTM2000 MAPSET: BH USER: roudierp DATE: Thu Sep 15 17:29:53 2011
COMMAND: v.clean input="foo" layer="1"
type="point,line,boundary,centroid,area,face,kernel" output="bar"
tool="rmar
ea" thresh=900
LOCATION: NZTM2000 MAPSET: BH USER: roudierp DATE: Thu Sep 15 17:31:45 2011
[Raster MASK present]
Pierre
2011/9/21 Markus Metz <markus.metz.giswork@googlemail.com>:
Markus,
Markus M
Dear list,
Markus M
Scientist
Scientist
BTW I confirm I got similar problems with the 6.4 series,
Pierre
2011/9/22 Pierre Roudier <pierre.roudier@gmail.com>:
Thanks Markus,
v.clean output:
tool="rmar
ea" thresh=900
Pierre
Markus,
Markus M
Dear list,
Markus M
Scientist
Scientist
Scientist
On Thu, Sep 22, 2011 at 5:26 AM, Pierre Roudier
Thanks for the input vector, I could reproduce the effect. But I am
not sure if this is really a problem. The method to remove small areas
finds the neighbouring area with which the longest boundary is shared.
This neighbouring area can also be the surrounding "nothing" in which
case the area is not merged with a real area but erased. That is, my
first comment was wrong, areas are not always merged with a
neighbouring real area, only if this neighbouring real area is the one
with the longest shared boundary. The cleaning tool assumes that small
areas are spurious and removes them by merging or by erasing. In case
of ties, when there are two neighbours with equally longest shared
boundary, as in your case, whichever neighbour is checked first will
be used. That neighbour can also be the empty space around.
Markus M
Thanks Markus,
v.clean output:
tool="rmar
ea" thresh=900
Pierre
Markus,
Markus M
Dear list,
Markus M
Scientist
Scientist
Scientist
Markus,
Thanks, that means this is no bug then.
However, in my specific case this behaviour is problematic (I do need
to merge small areas into existing/real areas), so maybe a suggestion
could be to control that behaviour through an option? Anyway, as I'm
not able to code it myself in C, so this is just a wish!
Thanks for the time you spent looking into my problem, this is much
appreciated as usual,
Pierre
2011/9/22 Markus Metz <markus.metz.giswork@googlemail.com>:
Markus M
Thanks Markus,
v.clean output:
tool="rmar
ea" thresh=900
Pierre
Markus,
Markus M
Dear list,
Markus M
Scientist
Scientist
Scientist
Scientist
