[GRASS-user] Rename multiple sqlite columns at once
Is there (hopefully?) any way to translate for example all Caps to lower
case letters in all column names of a vector maps attribute tavble
(stored in sqlite.db)?
Any way to apply similar techniques like with common GNU text utilities
(i.e. tr, sed, cut)?
Kind regards, Nikos
Kind regards, Nikos
The command
v.db.renamecol map=test_rencol column="AREA","area"
does not work. I assume that trying to use 'tr' for example wouldn't
help (?). Or am I doing something wrong?
Hello Nikos
The command
Try this:
#!/bin/sh
# # # in this example I use nc_spm_07 dataset
# # # I created a sqlite mapset
db.connect driver=sqlite \
  database='$GISDBASE/$LOCATION_NAME/$MAPSET/my_sqlitedb.db'
db.connect -p
g.copy vect=hospitals,myhospitals --overwrite
v.db.connect myhospitals -p
db.columns myhospitals
# use awk, function: tolower
# echo "MINNIE" | awk '{print tolower($1)}'
# minnie
# ...and function substr
# echo "minnie_tmp"| awk '{print substr($1,1,length($1)-length("_tmp"))}'
# minnie
#skip out duplicate column name error
# (no differences between lower and upper case)
key_field="cat"
suffix="_tmp"
#THIS MAY TAKE A WHILE...
for field in `db.columns myhospitals`; do
  if [ "$field" != "$key_field" ]; then
    tmpfield=`echo $field | awk '{print tolower($1)}'`
    tmpfield=$tmpfield$suffix
    v.db.renamecol map=myhospitals layer=1 column=$field,$tmpfield
    lower_field=`echo $tmpfield $suffix| awk '{print
substr($1,1,length($1)-length($2))}'`
    v.db.renamecol map=myhospitals layer=1 column=$tmpfield,$lower_field
  fi
done
there are same better and more elegant solutions probably...
ciao
Paolo
On Tue, 2008-11-04 at 10:35 +0100, Paolo Craveri wrote:
Hello Nikos
> The command
Try this:
#!/bin/sh
db.connect -p
# minnie
# minnie
key_field="cat"
suffix="_tmp"
  fi
done
ciao
Paolo
Ciao Paolo!
Looks like a nice learning-example to me :slight_smile:
It works!! But still I get some error/warning from "v.db.renamecol".
Don't know, I changed it a bit... :
#!/bin/sh
key_column="cat"
suffix="_tmp"
for column in `db.columns test`; do
        if [ "$column" != "$key_column" ]; then
                tempcolumn=`echo $column | awk '{print tolower($1)}'`
                tempcolumn=$tempcolumn$suffix
                v.db.renamecol map=test layer=1 column=$column,
$tempcolumn
                lower_column=`echo $tempcolumn $suffix| awk '{print
                v.db.renamecol map=test layer=1 column=$tempcolumn,
$lower_column
        fi
done
db.columns test
The error is:
Sorry <_tmp> is not a valid option
Grazie mille, Nikos
Hello Nikos
The command
Try this:
#!/bin/sh
db.connect -p
# minnie
# minnie
key_field="cat"
suffix="_tmp"
  fi
done
ciao
Paolo
Ciao Paolo!
#!/bin/sh
key_column="cat"
suffix="_tmp"
$tempcolumn
$lower_column
        fi
done
db.columns test
The error is:
I think you might have to escape _tmp with a backslash, i.e. "\_tmp".
Moritz
>> Hello Nikos
>>> The command
>> Try this:
>> #!/bin/sh
>> db.connect -p
>> # minnie
>> # minnie
>> key_field="cat"
>> suffix="_tmp"
>> fi
>> done
>> ciao
>> Paolo
> Ciao Paolo!
> #!/bin/sh
> key_column="cat"
> suffix="_tmp"
> $tempcolumn
> $lower_column
> fi
> done
> db.columns test
> The error is:
Moritz
Hi Moritz, The DB-Wizard :slight_smile:
I 've replaced "_tmp" with "\_tmp" but no luck.
DBMI-SQLite driver error:
Error in sqlite3_prepare():
unrecognized token: "\"
ERROR: Error while executing: 'ALTER TABLE test ADD COLUMN block_id\_tmp
       INTEGER
ERROR: Cannot continue (problem adding column).
ERROR: Cannot continue (problem renaming column)
Sorry <\_tmp> is not a valid option
Using only "tmp" I get: "Sorry <tmp> is not a valid option"
So, the problem is somewhere else and not in the string (?)
Kind regards, Nikos
I tried another example using "cut" this time.
#!/bin/sh
CAT="cat"
PREFIX="tmp_"
for COLUMN in `db.columns test`; do
        if [ "$COLUMN" != "$CAT" ]; then
                PRETEMP=`echo $COLUMN | awk '{print tolower($1)}'`
                TEMP=$PREFIX$PRETEMP
                v.db.renamecol map=test layer=1 column=$COLUMN,$TEMP
                lower_column=`echo $TEMP | cut -d"_" -f2`
                v.db.renamecol map=test layer=1 column=$TEMP,
$lower_column
        fi
done
db.columns test
It works (final columns are renamed/reported all with lower case letters
by db.columns) BUT it produces lots of errors? Is this a bug? Below the
details:
#initial test vector map
db.columns test
block_id
cat
AREA
PERIMETER
RAS2X2_
RAS2X2_ID
RAS2X2_NR
block
STAND
BEFL_DATUM
BEFL_JAHR
QUALITAET
# running the "cut" script
sh ./caps_2_lower_cut.sh
duplicate column name: block
ERROR: Error while executing: 'ALTER TABLE test ADD COLUMN block INTEGER
duplicate column name: ras2x2
ERROR: Error while executing: 'ALTER TABLE test ADD COLUMN ras2x2 DOUBLE
       PRECISION
       varchar(1)
WARNING: SQLite driver: unable to parse decltype: CHARACTER INTEGER
WARNING: SQLite driver: column 'tmp_block', SQLite type 1 is not
supported
supported
ERROR: Column <tmp_block> not found in table
duplicate column name: befl
ERROR: Error while executing: 'ALTER TABLE test ADD COLUMN befl INTEGER
cat
tmp_block_id
area
perimeter
ras2x2
tmp_ras2x2_id
tmp_ras2x2_nr
stand
befl
tmp_befl_jahr
qualitaet
Well, it does not work after all the way it should. Normally since my
column names have a "_" character. I am working on it... :slight_smile:
Hello Nikos
The command
Try this:
#!/bin/sh
db.connect -p
# minnie
# minnie
key_field="cat"
suffix="_tmp"
  fi
done
ciao
Paolo
Ciao Paolo!
#!/bin/sh
key_column="cat"
suffix="_tmp"
$tempcolumn
$lower_column
        fi
done
db.columns test
The error is:
Moritz
My suggestion did not concern any DB issues, but bash...
       INTEGER
I guess it doesn't work when you add it to a variable which you then use in concatenation.
Maybe you could just replace (in your original script)
with
tmpfield=$tmpfield\_tmp
But I'm not sure that this is where the problem lies.
Maybe you could add -x after /bin/sh at the beginning of your script to debug and see where the problem is.
Or just do an 'echo $tmpcolumn' before the v.db.renamecol to see what the variable contains.
Moritz
ciao to all
pay attention to spaces between column name in v.db.renamecol: no
spaces before and after comma.
Command substitution: backticks → $(....) not substantial
differences; the second form is easier to read and write; it is also
nestable (we are all used to ` ` form, but $() is better (IMHO))
This should work (probably):
db.columns test
key_column="cat"
suffix="_tmp"
               tempcolumn=$(echo $column | awk '{print tolower($1)}')
               v.db.renamecol map=test layer=1 column=$column,$tempcolumn
               lower_column=$(echo $tempcolumn $suffix| awk '{print
substr($1,1,length($1)-length($2))}')
               v.db.renamecol map=test layer=1 column=$tempcolumn,$lower_column
       fi
done
db.columns test
ciao
Paolo
On Thu, 2008-11-06 at 11:18 +0100, Paolo Craveri wrote:
ciao to all
db.columns test
key_column="cat"
suffix="_tmp"
       fi
done
db.columns test
ciao
Ciao Paolo & Moritz!
Thank you for your assistance.
@Moritz: I tried it but still not clean.
# cat caps_2_lower_moritzx.sh -n
     1 #!/bin/sh -x
     2
     3 key_column="cat"
     4 suffix="\_tmp"
     5 for column in `db.columns test`; do
     6 if [ "$column" != "$key_column" ]; then
     7 tempcolumn=`echo $column | awk '{print
tolower($1)}'`
     8 tempcolumn="$tempcolumn""\_tmp"
     9 echo $tempcolumn
    10 v.db.renamecol map=befliegung_copy column=
$column,$tempcolumn
    11 lower_column=`echo $tempcolumn $suffix | awk '{print
    12 substr($1,1,length($1)-length($2))}'`
    13 v.db.renamecol map=test layer=1 column=
    14 fi
    15 done
    16
    17 db.columns test
# output
block_id\_tmp
ERROR: Column <block_id> not found in table
## and the "Sorry..." message is repeated along with other stuff.
@Paolo:
I still get the "Sorry <_tmp> is not a valid option" message and the
final column names have the "_tmp" suffix! I did some testing but
nothing really clean came out.
Since I can't work it out I attempted this time with the "sed" utility.
Now it works with some warnings (relates with the column types?)!!
It looks like that:
     1 #! /bin/sh -x
     2 db.columns test
     3
     4 key_column="cat"
     5 suffix="_tmp"
     6 for column in `db.columns test`; do
     7 if [ "$column" != "$key_column" ]; then
     8 tempcolumn=$(echo $column | awk '{print tolower($1)}')
     9 tempcolumn=$tempcolumn$suffix
    10 echo $tempcolumn
    11 v.db.renamecol map=test layer=1 column=$column,$tempcolumn
    12 lower_column=`echo $tempcolumn | sed 's:'$suffix'::'`
    13 v.db.renamecol map=test layer=1 column=$tempcolumn,
$lower_column
    14 fi
    15
    16 done
    17 db.columns test
# Executing this script gives
sh ./caps_2_lower_sed.sh
block_id
cat
AREA
PERIMETER
RAS2X2_
RAS2X2_ID
RAS2X2_NR
block
STAND
BEFL_DATUM
BEFL_JAHR
QUALITAET
block_id_tmp
area_tmp
perimeter_tmp
ras2x2__tmp
ras2x2_id_tmp
ras2x2_nr_tmp
block_tmp
WARNING: SQLite driver: column 'block_tmp', SQLite type 1 is not
supported
supported
ERROR: Column <block_tmp> not found in table
stand_tmp
befl_datum_tmp
befl_jahr_tmp
qualitaet_tmp
cat
block_id
area
perimeter
ras2x2_
ras2x2_id
ras2x2_nr
stand
befl_datum
befl_jahr
qualitaet
I have checked the original vector map and all column types are grass- &
sqlite-acceptable I think (?)...
# db.describe
db.describe -c befliegung
ncols: 12
nrows: 361
Column 1: block_id:INTEGER:20
Column 2: cat:INTEGER:20
Column 3: AREA:DOUBLE PRECISION:20
Column 4: PERIMETER:DOUBLE PRECISION:20
Column 5: RAS2X2_:DOUBLE PRECISION:20
Column 6: RAS2X2_ID:DOUBLE PRECISION:20
Column 7: RAS2X2_NR:CHARACTER:13
Column 8: block:CHARACTER:40
Column 9: STAND:CHARACTER:16
Column 10: BEFL_DATUM:CHARACTER:16
Column 11: BEFL_JAHR:INTEGER:20
Column 12: QUALITAET:CHARACTER:16
But according to sqlitebrowser, the same attribute table has all "type"
entries written in lower case (that is: integer, double precision) and
instead of CHARACTER (or character) it is varchar(*somenumber here...*).
Question: why db.describe reports different column types?? I have
checked the db connection and it is linked to the correct sqlite.db
file.
ciao to all
db.columns test
key_column="cat"
suffix="_tmp"
       fi
done
db.columns test
ciao
     1 #!/bin/sh -x
     2
     3 key_column="cat"
     4 suffix="\_tmp"
tolower($1)}'`
     9 echo $tempcolumn
$column,$tempcolumn
# output
block_id\_tmp
I think this is because of the quotes:
But actually, trying out your entire original script, I don't see where the problem is. The attached version seems to work perfectly for me (just slightly simplified from your original version):
What exactly did not work when you tried this ?
Moritz
(attachments)
change_case.sh (413 Bytes)
On Thu, 2008-11-06 at 19:59 +0100, Moritz Lennert wrote:
> # output
> block_id\_tmp
where
Moritz
Moritz,
thank you for your time.
1. I *corrected* the double quotes and re-run the script. [Script +
output attached]
2. I tried your latest script (the one you attached in the previous
message). It works but I still get those column-type-related WARNINGS.
[Script + output attached]
Kind Regards, Nikos
(attachments)
caps_2_lower_moritzx2.output (6.98 KB)
change_case.output (1.32 KB)
# output
block_id\_tmp
Moritz
Moritz,
output attached]
You still use quotes:
tempcolumn="$tempcolumn\_tmp"
IIUC, the quotes will let the slash appear literally. So, just leave out the quotes as follows:
tempcolumn=$tempcolumn\_tmp
However, as you say your original script (in my modified form) actually worked, it just spit out a series of warnings. So it might be more interesting to check upon these warnings. I only saw these with the sqlite driver, not with dbf or postgresql, so we should try to find out what happens with that driver.
Moritz
Kind Regards, Nikos
# I *corrected* the tempcolumn="$tempcolumn""\_tmp"
## Actually it didn't work in first place this is why I experimented a bit by adding the double quotes!
     1 #!/bin/sh -x
     2
     3 key_column="cat"
     4 suffix="_tmp"
     7 tempcolumn=`echo $column | awk '{print tolower($1)}'`
     8 tempcolumn="$tempcolumn\_tmp"
     9 echo $tempcolumn
    10 v.db.renamecol map=befliegung_copy column=$column,$tempcolumn
    13 v.db.renamecol map=test layer=1 column=$tempcolumn,$lower_column
    14 fi
    15 done
    16
    17 db.columns test
# Output when running the above
sh ./caps_2_lower_moritzx.sh > caps_2_lower_moritzx2
Description:
Renames a column in the attribute table connected to a given vector map.
Keywords:
vector, database, attribute table
Usage:
v.db.renamecol map=name [layer=value] column=string[,string,...]
   [--verbose] [--quiet]
Flags:
--v Verbose module output
--q Quiet module output
Parameters:
     map Vector map for which to rename attribute column
   layer Layer where to rename column
           default: 1
  column Old and new name of the column (old,new)
ERROR: Column <AREA> not found in table
Description:
Keywords:
Usage:
Flags:
Parameters:
           default: 1
ERROR: Column <PERIMETER> not found in table
Description:
Keywords:
Usage:
Flags:
Parameters:
           default: 1
ERROR: Column <RAS2X2_> not found in table
Description:
Keywords:
Usage:
Flags:
Parameters:
           default: 1
ERROR: Column <RAS2X2_ID> not found in table
Description:
Keywords:
Usage:
Flags:
Parameters:
           default: 1
ERROR: Column <RAS2X2_NR> not found in table
Description:
Keywords:
Usage:
Flags:
Parameters:
           default: 1
ERROR: Column <block> not found in table
Description:
Keywords:
Usage:
Flags:
Parameters:
           default: 1
ERROR: Column <STAND> not found in table
Description:
Keywords:
Usage:
Flags:
Parameters:
           default: 1
ERROR: Column <BEFL_DATUM> not found in table
Description:
Keywords:
Usage:
Flags:
Parameters:
           default: 1
ERROR: Column <BEFL_JAHR> not found in table
Description:
Keywords:
Usage:
Flags:
Parameters:
           default: 1
ERROR: Column <QUALITAET> not found in table
Description:
Keywords:
Usage:
Flags:
Parameters:
           default: 1
[Raster MASK present]
# Moritz's script...
cat change_case.sh -n
     1 #!/bin/sh -x
     2
     3 key_column="cat"
     4 suffix="_tmp"
     5 map="test"
     8 tempcolumn=$column$suffix
     9 echo $tempcolumn
    10 v.db.renamecol map=$map column=$column,$tempcolumn
    11 lowercolumn=`echo $column | awk '{print tolower($1)}'`
    12 v.db.renamecol map=$map layer=1 column=$tempcolumn,$lowercolumn
    13 fi
    14 done
    15
    16 db.columns test
# running the above works but I still get some WARNINGS... ??
sh ./change_case.sh
block_id_tmp
AREA_tmp
PERIMETER_tmp
RAS2X2__tmp
RAS2X2_ID_tmp
RAS2X2_NR_tmp
block_tmp
WARNING: SQLite driver: column 'block_tmp', SQLite type 1 is not supported
STAND_tmp
BEFL_DATUM_tmp
BEFL_JAHR_tmp
QUALITAET_tmp
cat
block_id
area
perimeter
ras2x2_
ras2x2_id
ras2x2_nr
stand
befl_datum
befl_jahr
qualitaet
out
actually
out
Moritz
Oh, sorry Moritz. Now I see. I am at your service :slight_smile: Tell me what/how
to test?
At a glance:
* I have a shapefile with more than 30 columns (the test shapefile is
just a test).
* I imported in GRASS (using sqlite backend).
* sqlitebrowser reports "correct" column types (integere, double
precision, varchar)
* db.describe reports columnt type with CAPS and CHARACTER instead of
varchar
>> where
>> Moritz
> Moritz,
> output attached]
If you just want to prevent the underscore from being treated as part
of the variable name, use braces:
  tempcolumn=${tempcolumn}_tmp
or, if the variable's value may contain spaces::
  tempcolumn="${tempcolumn}_tmp"
Thanks Glynn. I suppose this way it's safer.
Moritz
to test?
Sorry, for not coming back on this earlier, but I think I found it now. The error (which also appears in other drivers, at least dbf), is due to the following line in v.db.renamecol:
oldcoltype="`db.describe -c table=$table database=$database\
    driver=$driver | grep $oldcol | cut -d':' -f3`"
If you have two columns with the name of the first a subset of the name of the second (e.g. DATA and DATA2, or in the nc_spm_06 dataset's comm_colleges map, CC_ and CC_NAME and CCL_ and CCL_ID), the grep in the above line will find both lines and result in an invalid oldcoltype:
GRASS 6.4.svn (nc_spm_06):~ > db.describe -c table=test | grep CC_ Column 7: CC_:CHARACTER:8
Column 8: CC_NAME:CHARACTER:30
GRASS 6.4.svn (nc_spm_06):~ > db.describe -c table=test | grep CC_ | cut -d':' -f3
CHARACTER
GRASS 6.4.svn (nc_spm_06):~ > oldcoltype="`db.describe -c table=test | grep CC_ | cut -d':' -f3`"
GRASS 6.4.svn (nc_spm_06):~ > echo $oldcoltype
CHARACTER CHARACTER
Which then obviously leads to an error as 'CHARACTER CHARACTER' is not a valid column type.
Can you confirm that this is the case for you as well ?
And actually this is not only a warning issue, but the column is lost because of this !
I don't have the time right now to try to figure out a solution, but you can either give it a try yourself, or file a bug report, and I'll get back to it when I have time.
Moritz
cut -d':' -f3
CHARACTER
CHARACTER
CHARACTER CHARACTER
valid column type.
because of this !
Well, not exactly. Columns are renamed in the end (even if some names
are "subsets" of other column names) but it looses a column which was
already in lower case!? See example below (using sqlite):
# some table
db.describe befliegung_copy -c
ncols: 12
nrows: 361
# using you script change_case.sh (added some echo's)
sh ./change_case.sh befliegung_copy
*Original* column name is: block_id
*Temporary* set to: block_id_tmp
New column name will be: block_id
*** Column block_id renamed to block_id :slight_smile: ***
*Original* column name is: AREA
*Temporary* set to: AREA_tmp
New column name will be: area
*** Column AREA renamed to area :slight_smile: ***
*Original* column name is: PERIMETER
*Temporary* set to: PERIMETER_tmp
New column name will be: perimeter
*** Column PERIMETER renamed to perimeter :slight_smile: ***
*Original* column name is: RAS2X2_
*Temporary* set to: RAS2X2__tmp
New column name will be: ras2x2_
*** Column RAS2X2_ renamed to ras2x2_ :slight_smile: ***
*Original* column name is: RAS2X2_ID
*Temporary* set to: RAS2X2_ID_tmp
New column name will be: ras2x2_id
*** Column RAS2X2_ID renamed to ras2x2_id :slight_smile: ***
*Original* column name is: RAS2X2_NR
*Temporary* set to: RAS2X2_NR_tmp
New column name will be: ras2x2_nr
*** Column RAS2X2_NR renamed to ras2x2_nr :slight_smile: ***
*Temporary* set to: block_tmp
supported
supported
*** Column block renamed to block :slight_smile: ***
*Original* column name is: STAND
*Temporary* set to: STAND_tmp
New column name will be: stand
*** Column STAND renamed to stand :slight_smile: ***
*Original* column name is: BEFL_DATUM
*Temporary* set to: BEFL_DATUM_tmp
New column name will be: befl_datum
*** Column BEFL_DATUM renamed to befl_datum :slight_smile: ***
*Original* column name is: BEFL_JAHR
*Temporary* set to: BEFL_JAHR_tmp
New column name will be: befl_jahr
*** Column BEFL_JAHR renamed to befl_jahr :slight_smile: ***
*Original* column name is: QUALITAET
*Temporary* set to: QUALITAET_tmp
New column name will be: qualitaet
*** Column QUALITAET renamed to qualitaet :slight_smile: ***
Result is...
cat
block_id
area
perimeter
ras2x2_
ras2x2_id
ras2x2_nr
stand
befl_datum
befl_jahr
qualitaet
# initial column "block" got lost :frowning:
Moritz
Hope this helps.
Regards, Nikos
I haven't really been following this thread (or know much about it), but
I spotted this tip on the gdal site, maybe it helps:
http://www.gdal.org/ogr/drv_gpx.html
# Use of -sql option to remap field names to the ones allowed by the GPX schema !
ogr2ogr -f GPX output.gpx input.shp -sql "SELECT field1 AS name, field2 AS desc FROM source_layer"
Hamish
