On 01/09/17 06:41, Ken Mankoff wrote:
Hi Micha,
We are getting closer to the issue. Unfortunately I'm also becoming more certain the limitation is real and in GRASS and not my mental model. If this email does not clarify it, I will draw a picture which may help.
On 01 Sep 2017, at 00:08, Micha Silver <tsvibar@gmail.com <mailto:tsvibar@gmail.com>> wrote:
You won't have many upstream cells for those cells along the basin boundary, only the few that drain exactly along the watershed divide.
I think you are picturing the NC data set and mountains. Greenland is flatter. Why can't a divide in an extreme case be near or across a lake? Or alternatively, why can't a major stream flow along the boundary outside of a divide? In these cases the boundary cells contribute 49%, but have large (massive?) upstream catchments themselves, all of which is excluded if a mask is generated from r.water.outlet. If I were only losing the boundary cells (max of n of them, for a boundary n cells long), I would not worry. This seems like the case in mountainous regions, but perhaps not on the flatter Greenland ice sheet.
The only way that r.watershed can return different results is if you input a different elevation grid.
R.watershed w/o flow -> r.water.outlet produces a "minimum" basin where partial contributor cells (and the upstream catchments of those cells) are not included.
R.watershed WITH flow produces runoff at point x,y with the contribution from other catchments that partially contribute to this catchment.
Correct?
I think so. If you know how much overland flow you have in each cell (= flow parameter), then r.watershed should calculate the accumulation of that flow along the way based on the extremely simplified assumption that all that flow remains overland across such a large area.
But I won't get more into the actual sens of doing this as others have done this very well.
However, to get to you original problem, you wrote:
"If I do "r.watershed" ~14,000 times I'll get the results, but it will take 3 days."
First of all, 3 days running time is not that bad for such an amount of data. We're talking less than 20 seconds for each run...
My answer to this would be parallelization. If you have enough cores and enough memory (but IIRC r.watershed does not need that much), you can make this go much faster, as each run is independent of the others (again IIUC). So, if you have 8 cores to spare, you can divide the time by (probably a bit less than) 8...
You can look at [1] for some general information and [2] for a specific GRASS Python API module for that.
Moritz
[1] https://grasswiki.osgeo.org/wiki/Parallelizing_Scripts
[2] https://grass.osgeo.org/grass73/manuals/libpython/pygrass.modules.interface.html?highlight=parallelmodulequeue#pygrass.modules.interface.module.ParallelModuleQueue
Moritz
