i have 2 maps i want to use, but i need to position them correctly. The problem is the corners have different values, meaning Left top X, is not the same has Bottom top left X, so i cant use N;S;W;E has usual.
how do i solve this situation?
Thanks
Thanks
found the solution here: http://grass.itc.it/gdp/html_grass63/projectionintro.html
i thought it was using r.region or something similar but i can see that it requires a more effort.
Ricardo
-----Original Message-----
From: grassuser-bounces@grass.itc.it on behalf of Ricardo Oliveira
Sent: Wed 5/23/2007 5:27 PM
To: grassuser@grass.itc.it
Subject: [GRASS-user] reposition imageā¦again
Thanks
