[GRASS-user] REPOSTING: Extrusion of vectors based on attribute results to vectors with zero height
REPOSTING PENDING MESSAGE
View this message in context: REPOSTING: Extrusion of vectors based on attribute results to vectors with zero height
Hello all,
Does anyone know if the v.trees3D vector add-on (for extruding trees from points) is still accessible? Can’t find it in the current svn so I am assuming not… if this is the case does anyone have any other cool suggestions for auto-modelling 3D trees from point data?
Thanks for reading,
Rebecca
2013/3/27 Rebecca Bennett <rabennett@ymail.com>:
points) is still accessible? Can't find it in the current svn so I am
assuming not... if this is the case does anyone have any other cool
I found the source code of this module at [1] (cc'ed original author
Jachym Cepicky, could be that he is planning to upload his modules to
AddOns SVN :slight_smile:
Martin
[1] http://les-ejk.cz/files/programs/grass/v.trees3d.tar.gz
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Thanks for the link Martin.
I did a bit of digging and found these instructions for adding the v.trees3D add-on without using g.extension
http://les-ejk.cz/programs/?cat=gis#### InstallationIf it is an tgz package, it is most probably the C-source code:
  • Copy the file in the GRASS source directory to proper directory (raster
    modules in raster, vector in vector etc.).
  • Untar the archive with tar xzf modulename.tgz
  • Go to the new module directory and run make:
    cd modulename
    make
  • Go to the GRASS source directory and run make install for
    installing it.
Can anyone tell me if these are still valid - I only ask because I don’t see separate directories for raster and vector modules in my install (~usr/lib/Grass64/bin, GRASS version: 6.4.3RC2 on Ubuntu 12.04 precise)?
To: Rebecca Bennett rabennett@ymail.com
Cc:grass-user@lists.osgeo.orggrass-user@lists.osgeo.org; Jachym Cepicky jachym.cepicky@gmail.com
Sent: Wednesday, 27 March 2013, 16:16
Subject: Re: [GRASS-user] v.trees3D
I found the source code of this module at [1] (cc’ed original author
Martin
Yes that still works–it also works for python modules, but you add it to wherever you unpacked your grass source code (such as in ~/source/grass_trunk), not where grass is installed. Did you compile grass or are you using a version from the repos?
Eric
    cd modulename
    make
    installing it.
To: Rebecca Bennett <rabennett@ymail.com>
Cc:grass-user@lists.osgeo.org” <grass-user@lists.osgeo.org>; Jachym Cepicky <jachym.cepicky@gmail.com>
Martin
grass-user mailing list
