[GRASS-user] reproject from lat/long to utm
HI,
thanx for any help. seems this should be a pretty straight forward thing to do, but am not having any success.
i am trying to reproject a raster from lat/long to utm.
i created a new location with a utm projection, then tried to use r.proj to reproject a raster from another location.
r.proj input=dem location=/work/projects/Willamette mapset=PERMANENT
however, i get the following error:
Mapset [PERMANENT] in input location [/work/projects/Willamette] - not found
thanx for any assistance,
Janet
Try to include the full path of your location ([/work/projects/Willamette])
On Wed, Dec 2, 2009 at 1:47 PM, Janet Choate <jsc.eco@gmail.com> wrote:
HI,
Janet
grass-user mailing list
grass-user@lists.osgeo.org
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
I tried using the full path (i.e. the PERMANENT mapset lives within the /work/projects/Willamette location), but get the ‘not found’ error.
is there any other command i need to run prior to r.proj, or any additional options to include, or how to list the path other than the way i am?
the original data i imported was a dem from usgs national elevation dataset (ned) seamless data distribution system (sdds). i had to export it from ned as a geotiff to bring it into grass. i tried exporting the data from ned as an arcgrid and importing into grass with r.in.gdal, but was unable to bring it into grass.
so if anyone can tell me the steps to bringing ned seamless data into grass, then reprojecting to utm, i would be grateful. or at this point, just how to use r.proj to reproject to utm.
thanx, janet
On Tue, Dec 1, 2009 at 10:14 PM, maning sambale <emmanuel.sambale@gmail.com> wrote:
HI,
Janet
cheers,
maning
“Freedom is still the most radical idea of all” -N.Branden
/work/projects/Willamette location), but get the 'not found' error.
just to check from your lat/long mapset, run g.gisenv
It should show you the location, mapset and GRASS database.
This is what you use in r.proj parameters
it into grass.
thanx, janet
> HI,
> thing to
> to
> found
> Janet
cheers,
maning
cheers,
maning
try this:
r.proj input=dem dbase=/work/projects/ location=Willamette mapset=PERMANENT
On Wed, Dec 2, 2009 at 2:45 PM, maning sambale
it into grass.
thanx, janet
> HI,
> thing to
> to
> found
> Janet
cheers,
maning
cheers,
maning
cheers,
maning
ok, getting somewhere!
however, now i’m getting the error ‘Input map is outside current region’, which must be due to how i set up the new location. when i set up the new location/mapset, for ‘define new location with…’
i chose ‘Projection values’
then gave a new location name=GRASSnew, mapset=PERMANENT, database=/work/projects
then specified the coordinate system for the new location as UTM,
datum nad83, datum tranformation Parameters chose option 6, zone 10, then on the define the default region page - left the default region as it was with N and E edge at 1, W and S edge at 0, and leaving Grid Resolution at 1, accepted this region, successfully created location and reentered grass.
then ran r.proj as you suggested, and appeared to be correct input, but got the input map is outside current region error.
any ideas?
thanx for all you help!
On Tue, Dec 1, 2009 at 10:50 PM, maning sambale <emmanuel.sambale@gmail.com> wrote:
try this:
it into grass.
thanx, janet
HI,
thing to
to
found
Janet
cheers,
maning
cheers,
maning
cheers,
maning
