Vincent,
Vincent BAIN wrote:
Hello Richard,
don't know if it can help, but for me it works, from conformal conic
Lambert to rgf93 (the official geographic coord system in France,
compliant with wgs84).
Could you send us the proj information from each of your locations, and
make sure they correspond to your project ?
The XY location was defined using EPSG code 20356 (Australia from Geosciences). It shows UTM projection, zone 56, AGD84 datum, and ellipsoid data.
The LCC location was "self-defined" during import - that is, I created a new location during import. The project info it created is below:
g.region -p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: towgs84=-134,-48,149,-0,-0,-0,0
ellipsoid: a=6378160 es=0.006694541854587638
north: 6784163.1212489
south: 3123142.28999373
west: 2961606.17926652
east: 6874125.97609581
nsres: 183051.04156276
ewres: 195625.98984146
rows: 20
cols: 20
cells: 400
The problem is that I don't know what EPSG code the creator of the mapset I'm trying to import was using!
I advise you to define the coordinate systems from epsg codes, the best
way -- i think -- to avoid problems defining the right ellipsoïd, datum,
and so on...
And be cautious: the coordinates read from the display are decimal...
<whacks forehead> I suspect you're telling me I should be using degree-minute-second format in my transformation?
Thanks, I will go back and look at how I can get the projections lined up ... I might try defining a standard Australian LCC and see if the import works; then from a standard location to a standard location might well be easier.
Richard
Bon courage,
Vincent
Le samedi 11 août 2007 à 09:32 +1000, Richard Chirgwin a écrit :
It's me again ... I suspect I must be stupider than most Grass users because I seem to be hitting the list with questions so often!
I have my own maps which are in lat-long format, using Australian boundaries.
I need to analyse some points relative to some centroids supplied in MapInfo format. They import fine, but they're in Lambert Conformal Conical projection.
Without being long-winded, my attempts to reproject the LCC location into a lat-long UTM using WGS84 keep failing - the utilities work but the result isn't right.
Is there something about LCC projections that make them hard to reproject?
Richard
grassuser mailing list
grassuser@grass.itc.it
