Greetings
I would like to know which methods are available to upscale (or resample) a raster map from 50 m to 100 m?
And How shall I manage the g.region definitons? Before i run a resampling method shall i define g.region Spatial resolution as 100 or only after?
Thhanks
Kim
For resapling to a coarser resolution, where one output cell covers
multiple input cells, use r.resamp.stats.
For resampling to a finer resolution, use r.resamp.interp,
r.resamp.rst or (in 7.0) r.resamp.filter.
Set the region to the desired output resolution. The input will be
read at its native resolution.
