[GRASS-user] Retaining the raster name, while exporting a group to other formats
Hi all
I am exporting a group of rasters to single stacked GTiff and ENVI format files.
Here is my group:
i.group S2A_OPER_MSI_L1C_TL_MTI__20160810T122618_A005911_T30SWJ_10m -l
group <S2A_OPER_MSI_L1C_TL_MTI__20160810T122618_A005911_T30SWJ_10m> references the following raster maps
S2A_OPER_MSI_L1C_TL_MTI__20160810T122618_A005911_T30SWJ_B02.jp2@barrax
S2A_OPER_MSI_L1C_TL_MTI__20160810T122618_A005911_T30SWJ_B03.jp2@barrax
S2A_OPER_MSI_L1C_TL_MTI__20160810T122618_A005911_T30SWJ_B04.jp2@barrax
S2A_OPER_MSI_L1C_TL_MTI__20160810T122618_A005911_T30SWJ_B08.jp2@barrax
I use the following export command:
r.out.gdal input=${BASE}_10m output=“${MYDATA}/${FOLDER}Barrax/20m/${BASE}_10m” format=ENVI
But the band names in the output ENVI or GTiff files are changed to “Band 1”, “Band 2”, “Band 3”, “Band 4”.
Is there any way to retain the original raster names for the individual bands in the final stacked image?
Thanks in advance
Regards
Sajid
Sajid,
maybe not useful (?): t.rast.export does that for registered maps.
Maybe fake a strds or check the code there-in?
Nikos
* Sajid Pareeth <spareeth@gmail.com> [2016-11-10 10:02:07 +0100]:
Hi all
files.
Here is my group:
<S2A_OPER_MSI_L1C_TL_MTI__20160810T122618_A005911_T30SWJ_B02.jp2@barrax>
<S2A_OPER_MSI_L1C_TL_MTI__20160810T122618_A005911_T30SWJ_B03.jp2@barrax>
<S2A_OPER_MSI_L1C_TL_MTI__20160810T122618_A005911_T30SWJ_B04.jp2@barrax>
<S2A_OPER_MSI_L1C_TL_MTI__20160810T122618_A005911_T30SWJ_B08.jp2@barrax>
output="${MYDATA}/${FOLDER}Barrax/20m/${BASE}_10m" format=ENVI
But the band names in the output ENVI or GTiff files are changed to "Band
1", "Band 2", "Band 3", "Band 4".
Thanks in advance
Regards
Sajid
grass-user mailing list
grass-user@lists.osgeo.org
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
On Thu, Nov 10, 2016 at 10:02 AM, Sajid Pareeth <spareeth@gmail.com> wrote:
Hi all
Here is my group:
In GDAL, raster bands do not have names, they are numbered. The name of each input band could be used as description with GDALSetDescription() or the input name could also be stored as a band-specific metadata item. In any case, it depends on the output format if the input name can be used as description or for a band-specific metadata item. With GDALSetDescription(), gdalinfo would then report e.g.
Band 1 Block=1678x1 Type=Float64, ColorInterp=Gray
Description = elev_state_500m
Other applications including r.in.gdal might not check for any band-specific description upon import.
Markus M
