[GRASS-user] retrieve centroids from polygons
how can I extract the centroids from polygons and transform them into a point vector layer ? I have tiny polygons as groundtruth data for a satellite image analysis and I would like to retrieve the centroids as points so that I can use v.what.rast, in order to obtain the spectral information for the groundtruth data.
Best regards
Niels
Dr. Niels Thevs
Chair of Geobotany and Landscape Ecology
Institute of Botany and Landscape Ecology
Greifswald University
Grimmer Strasse 88
17487 Greifswald
Germany
Tel.: +49-3834-86-4132
Fax: +49-3834-86-4114
On Mon, 2008-12-01 at 14:57 +0100, Niels Thevs wrote:
Best regards
Niels
Hi Niels!
You probably need to use "v.extract type=centroid".
Regards, Nikos
On 01/12/08 14:57, Niels Thevs wrote:
v.extract in=map_polygons type=centroid out=map_centroids
v.type in=map_centroids out=map_points type=centroid,point
Moritz
