do the modules of R (e.g. r.stats, ...) have return values which I can
evaluate to find out if the execution was successful? E.g. returning
-1 when an error occurred?
I would like to use these "return values on error" to evaluate the
success of the command when called from R.
Centre of Excellence for Invasion Biology
Faculty of Science
Natural Sciences Building
Private Bag X1
University of Stellenbosch
Matieland 7602
South Africa
which I can evaluate to find out if the execution was successful?
Yes. GRASS modules all return 0 on success and 1 on failure.
In most cases you can trust that method. Maybe 1% of modules use a
different failure code, if so it's a bug & please report it.
Some/many of the internal C functions will use 1 as success, but they
will typically be called G_is_something() and return a boolean result.
The lib fns return all sorts of things, always check before using them.
Good to know - thanks as lot
Rainer
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
