[GRASS-user] Returning values to Python
Hi
Firstly I apologize if this is a duplicate, but I am not getting my
own posts emailed to me, and I don't see them in the list archive, so
I am using another email account.
How does one return attribute values from a call to the 'r.what'
module running in a python script?
When this query executes, it prints the result to the terminal, but I
need to get the value back in the script.
One of the documentation pages mentioned a function "stdout2dict" from
"grass.pygrass.modules", but it does not look like this is in the
pygrass package any longer?
Many thanks, Kevin
If you use grass.script.raster_what(), it returns a list of
dictionaries.
AFAICT, PyGRASS requires you to add stdout_=PIPE, then you can get the
output as a string from module.outputs["stdout"].value.
On Thu, Oct 30, 2014 at 8:04 AM, Glynn Clements
dictionaries.
or simplier: module.outputs.stdout
or using directly the C API through python with:
from grass.pygrass.vector import VectorTopo
from grass.pygrass.raster import RasterRow
from grass.pygrass.gis.region import Region
with RasterRow('elevation', mode='r') as rast:
    with VectorTopo('hospitals', mode='r') as hospitals:
        region = Region()
        for hosp in hospitals:
            value = rast.get_value(hosp, region)
            if value is not None:
                print(hosp.cat, value)
Pietro
Thank you all!
Cheers, Kevin
dictionaries.
        region = Region()
Pietro
