Greetings all,
I have a number of imported images which r.in.gdal has saved as separate RGB files - what command can combine these into a single raster?
Richard Chirgwin
Greetings all,
Richard Chirgwin
r.composite will do this, but you will get either better results or
better performance if you keep them as separate bands.
The default of levels=32 will reduce the colour depth to 15 bpp, while
using levels=256 will result in a significant increase in CPU
consumption for anything which converts cell values to colours (e.g.
d.rast).
