I’m looking for a method to parition a road network in k connected subgraphs around a starting node (i.e. the source node must be on a subgraph cut edge of each subgraph).
Is there anyone that have solved this kind of problem within GRASS?
Giovanni
Giovanni Allegri
http://about.me/giovanniallegri
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
I try to explain my problem with an example:
I have 3 vehicles that must do some work on a road netowk.
The morning they will leave the station and will go to their working area.
I need to partition the road network under the following heursitic constraints:
the subgraphs must be connected
they must have similar graph density
the transfer time for the vehicles must be similar
I can start simplifying the problem: paritioning the road graph in k subraphs, “radially” around the station, with k the number of vehicles.
giovanni
2013/9/5 G. Allegri <giohappy@gmail.com>
Giovanni
Giovanni Allegri
Giovanni Allegri
constraints:
- the subgraphs must be connected
- they must have similar graph density
- the transfer time for the vehicles must be similar
subraphs, "radially" around the station, with k the number of vehicles.
Maybe you can try to create k nodes that are all very close to the starting point, but in different directions and then run v.net.alloc ?
Moritz
Good point Moritz, I will try your trick and I will let you know
2013/9/5 Moritz Lennert <mlennert@club.worldonline.be>
constraints:
Moritz
Giovanni Allegri
