[GRASS-user] row() and col() problem
Jarosław Jasiewicz wrote:
I try to generate map where every cell will have unique value
I do that with following mapcalc formula:
map=(row()*451)+col()
where 451 is the total number of columns + 1
I expected following solution;
452,453,454,455,....
953,954,955,956,....
But I recived:
452,452,453,454,454,....
Where is the error in formula (or it is rounding problem)?
did you change the g.region resolution after creating the map?
if you do 'g.region rast=map' before output is it ok?
Hamish
Hamish pisze:
But I recived:
Yes, but not
Hamish
well, the problem may lays elsewhere
r.stats -1 input=map shows expected result, but when I use "display cell values layer" form gis.m it shows wrong results. It change default region as I know.
thanks
Jarek
