[GRASS-user] Rscript error when using v.class.mlR
Hi everyone,
When using the extension “v.class.mlR” I get an error [Message 1] (see below) that “Rscript” cannot be located. I traced this back to the script for “v.class.mlR” and edited line 908 to read the direct path to Rscript - ‘/usr/local/bin/Rscript’ rather than ‘Rscript’ alone. However, when I re-open GRASS 8.0 I get an error [Message 2] that the extension failed when loading and that the operation isn’t permitted. I allowed for the application to have administrative rights but it still doesn’t work. Does anyone know how to work around this or solve the issue finding “Rscript”?
I have R running and have installed necessary packages. I’m running GRASS on MacOS Monterey.
Any help would be appreciated.
  • Daniel
Thank you,
Daniel Kozar
PhD Candidate
UC Davis - Hydrologic Sciences
djkozar@ucdavis.edu
(814) 380-6900
Hi
On 19/02/2022 04:27, Daniel Kozar via grass-user wrote:
Hi everyone,
When using the extension "v.class.mlR" I get an error [Message 1] (see below) that "Rscript" cannot be located. I traced this back to the script for "v.class.mlR" and edited line 908 to read the direct path to Rscript - '/usr/local/bin/Rscript' rather than 'Rscript' alone. However, when I re-open GRASS 8.0 I get an error [Message 2] that the extension failed when loading and that the operation isn't permitted. I allowed for the application to have administrative rights but it still doesn't work. Does anyone know how to work around this or solve the issue finding "Rscript"?
I have R running and have installed necessary packages. I'm running GRASS on MacOS Monterey.
This looks like a Mac problem (which I know nothing about).
To test, can you run, first from a terminal:
micha@RMS:~$ Rscript -e "sessionInfo()"
Now run the same from within a GRASS session:
(here's what I get)
micha@RMS:QGIS$ g.version
GRASS 8.1.dev (2022)
micha@RMS:QGIS$ Rscript -e "sessionInfo()"
R version 4.1.2 (2021-11-01)
Platform: x86_64-pc-linux-gnu (64-bit)
Running under: Debian GNU/Linux 11 (bullseye)
Matrix products: default
BLAS: /usr/lib/x86_64-linux-gnu/openblas-pthread/libblas.so.3
LAPACK: /usr/lib/x86_64-linux-gnu/openblas-pthread/libopenblasp-r0.3.13.so
locale:
[1] LC_CTYPE=en_GB.UTF-8 LC_NUMERIC=C
[3] LC_TIME=en_GB.UTF-8 LC_COLLATE=en_GB.UTF-8
[5] LC_MONETARY=en_GB.UTF-8 LC_MESSAGES=en_GB.UTF-8
[7] LC_PAPER=en_GB.UTF-8 LC_NAME=C
[9] LC_ADDRESS=C LC_TELEPHONE=C
[11] LC_MEASUREMENT=en_GB.UTF-8 LC_IDENTIFICATION=C
attached base packages:
[1] stats graphics grDevices utils datasets methods base
loaded via a namespace (and not attached):
[1] compiler_4.1.2
If the Rscript executable is not found, then v.class.mlR cannot be run.
- Daniel
*[Message 1]*
Running R now. Following output is R output.
File "/Users/dankozar/Library/GRASS/8.0/Addons/scripts/v.class.mlR", line 977, in <module>
main()
File "/Users/dankozar/Library/GRASS/8.0/Addons/scripts/v.class.mlR", line 908, in main
subprocess.check_call(
File "/Applications/GRASS-8.0.app/Contents/Resources/lib/python3.9/subprocess.py", line 368, in check_call
retcode = call(*popenargs, **kwargs)
File "/Applications/GRASS-8.0.app/Contents/Resources/lib/python3.9/subprocess.py", line 349, in call
with Popen(*popenargs, **kwargs) as p:
File "/Applications/GRASS-8.0.app/Contents/Resources/lib/python3.9/subprocess.py", line 951, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "/Applications/GRASS-8.0.app/Contents/Resources/lib/python3.9/subprocess.py", line 1821, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'Rscript'
*[Message 2]*
Details: <[Errno 1] Operation not permitted: 'v.class.mlR'>
WARNING: Some addons failed when loading. Please consider to update your addons by running 'g.extension.all -f'.
Thank you,
Daniel Kozar
PhD Candidate
djkozar@ucdavis.edu
(814) 380-6900
grass-user mailing list
grass-user@lists.osgeo.org
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Hi Micha,
Thanks for the reply. I ran the script lines you sent both in the terminal as well as a GRASS session. Rscript is recognized in the terminal command but not in the GRASS 8.0 command. Since GRASS 8.0 did not recognize Rscript I tried making a symbolic link for “Rscript” to the full path: /usr/local/bin/Rscript. This still doesn’t recognize the command and I’m unsure how else to work around it.
Any Mac aficionados reading this - do you have an idea to resolve this?
Thanks
Daniel
On Sat, Feb 19, 2022 at 1:46 AM Micha Silver <tsvibar@gmail.com> wrote:
Hi
Hi everyone,
micha@RMS:~$ Rscript -e “sessionInfo()”
(here’s what I get)
micha@RMS:QGIS$ Rscript -e “sessionInfo()”
locale:
[1] compiler_4.1.2
  • Daniel
[Message 1]
File “/Users/dankozar/Library/GRASS/8.0/Addons/scripts/v.class.mlR”,
line 977, in
main()
line 908, in main
File
“/Applications/GRASS-8.0.app/Contents/Resources/lib/python3.9/subprocess.py”,
File
line 349, in call
File
line 951, in init
File
FileNotFoundError: [Errno 2] No such file or directory: ‘Rscript’
[Message 2]
Details: <[Errno 1] Operation not permitted: ‘v.class.mlR’>
your addons by running ‘g.extension.all -f’.
Thank you,
Daniel Kozar
PhD Candidate
djkozar@ucdavis.edu
(814) 380-6900
Micha Silver
Ben Gurion Univ.
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Daniel,
I assume you use the official GRASS app bundle for mac. If you are not using the final 8.0.0 version, but one of the release candidates, I'd suggest you download the latest. There are changes in the startup script in the final version that relate to PATH issues like this.
Best,
Nicklas
On Sunday, 20 February 2022, 01:55:28 CET, Daniel Kozar via grass-user <grass-user@lists.osgeo.org> wrote:
Hi Micha,
Thanks for the reply. I ran the script lines you sent both in the terminal as well as a GRASS session. Rscript is recognized in the terminal command but not in the GRASS 8.0 command. Since GRASS 8.0 did not recognize Rscript I tried making a symbolic link for "Rscript" to the full path: /usr/local/bin/Rscript. This still doesn't recognize the command and I'm unsure how else to work around it.
Thanks
Daniel
Hi
Hi everyone,
(here's what I get)
BLAS: /usr/lib/x86_64-linux-gnu/ openblas-pthread/libblas.so.3
LAPACK: /usr/lib/x86_64-linux-gnu/ openblas-pthread/libopenblasp- r0.3.13.so
locale:
[1] compiler_4.1.2
- Daniel
*[Message 1]*
File "/Users/dankozar/Library/ GRASS/8.0/Addons/scripts/v. class.mlR",
main()
line 908, in main
File
"/Applications/GRASS-8.0.app/ Contents/Resources/lib/ python3.9/subprocess.py",
File
line 349, in call
File
File
raise child_exception_type(errno_ num, err_msg, err_filename)
*[Message 2]*
Thank you,
Daniel Kozar
PhD Candidate
djkozar@ucdavis.edu
(814) 380-6900
______________________________ _________________
https://lists.osgeo.org/ mailman/listinfo/grass-user
Micha Silver
Ben Gurion Univ.
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Dear all,
What was the solution to this error? I recently got a similar error from the same module v.class.mlR. I am using GRASS GIS 8.2.1 on Windows 10.
Best,
Jamille
File “C:\Users\haarlooj\AppData\Roaming\GRASS8\addons\scri
pts[v.class.mlR.py](http://v.class.mlR.py)”, line 977, in
main()
pts[v.class.mlR.py](http://v.class.mlR.py)”, line 908, in main
File “C:\OSGeo4W\apps\Python39\lib\subprocess.py”, line
368, in check_call
349, in call
951, in init
close_fds,
1420, in _execute_child
hp, ht, pid, tid = _winapi.CreateProcess(executable,
args,
FileNotFoundError: [WinError 2] The system cannot find the
file specified
On Sun, Feb 20, 2022 at 8:24 AM Nicklas Larsson via grass-user <grass-user@lists.osgeo.org> wrote:
Daniel,
I assume you use the official GRASS app bundle for mac. If you are not using the final 8.0.0 version, but one of the release candidates, I’d suggest you download the latest. There are changes in the startup script in the final version that relate to PATH issues like this.
Best,
Nicklas
Hi Micha,
Thanks
Daniel
Hi
Hi everyone,
(here’s what I get)
locale:
[1] compiler_4.1.2
  • Daniel
[Message 1]
File “/Users/dankozar/Library/ GRASS/8.0/Addons/scripts/v. class.mlR”,
line 977, in
main()
line 908, in main
File
“/Applications/GRASS-8.0.app/ Contents/Resources/lib/ python3.9/subprocess.py”,
File
line 349, in call
File
line 951, in init
File
[Message 2]
Thank you,
Daniel Kozar
PhD Candidate
djkozar@ucdavis.edu
(814) 380-6900
Micha Silver
Ben Gurion Univ.
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Hi Jamille
On 15/07/2023 2:04, Jamille Haarloo wrote:
Dear all,
The previous post was in reference to MacOS. Can you check on your system that the Rscript executable is available from the GRASS command window? i.e.
- start grass (even without the GUI)
- go to the command shell
- run Rscript -e "sessionInfo()"
This will identify if the problem is due to missing PATH in the env variables.
Best,
Jamille
File "C:\Users\haarlooj\AppData\Roaming\GRASS8\addons\scri
pts\v.class.mlR.py <http://v.class.mlR.py>", line 977, in <module>
main()
pts\v.class.mlR.py <http://v.class.mlR.py>", line 908, in main
File "C:\OSGeo4W\apps\Python39\lib\subprocess.py", line
368, in check_call
349, in call
951, in __init__
close_fds,
args,
file specified
    Daniel,
    issues like this.
    Best,
    Nicklas
    Hi Micha,
    around it.
    this?
    Thanks
    Daniel
    wrote:
    > Hi
    > On 19/02/2022 04:27, Daniel Kozar via grass-user wrote:
    >> Hi everyone,
    >> When using the extension "v.class.mlR" I get an error [Message
    1] (see
    >> below) that "Rscript" cannot be located. I traced this back to the
    >> script for "v.class.mlR" and edited line 908 to read the direct
    path
    >> to Rscript - '/usr/local/bin/Rscript' rather than 'Rscript' alone.
    >> However, when I re-open GRASS 8.0 I get an error [Message 2]
    that the
    >> extension failed when loading and that the operation isn't
    permitted.
    >> I allowed for the application to have administrative rights but it
    >> still doesn't work. Does anyone know how to work around this or
    solve
    >> the issue finding "Rscript"?
    >> I have R running and have installed necessary packages. I'm
    >> running GRASS on MacOS Monterey.
    > This looks like a Mac problem (which I know nothing about).
    > To test, can you run, first from a terminal:
    > micha@RMS:~$ Rscript -e "sessionInfo()"
    > Now run the same from within a GRASS session:
    > (here's what I get)
    > micha@RMS:QGIS$ g.version
    > GRASS 8.1.dev <http://8.1.dev> (2022)
    > micha@RMS:QGIS$ Rscript -e "sessionInfo()"
    > R version 4.1.2 (2021-11-01)
    > Platform: x86_64-pc-linux-gnu (64-bit)
    > Running under: Debian GNU/Linux 11 (bullseye)
    > Matrix products: default
    > BLAS: /usr/lib/x86_64-linux-gnu/ openblas-pthread/libblas.so.3
    > LAPACK: /usr/lib/x86_64-linux-gnu/
    openblas-pthread/libopenblasp- r0.3.13.so <http://r0.3.13.so>
    > locale:
    > [1] LC_CTYPE=en_GB.UTF-8 LC_NUMERIC=C
    > [3] LC_TIME=en_GB.UTF-8 LC_COLLATE=en_GB.UTF-8
    > [5] LC_MONETARY=en_GB.UTF-8 LC_MESSAGES=en_GB.UTF-8
    > [7] LC_PAPER=en_GB.UTF-8 LC_NAME=C
    > [9] LC_ADDRESS=C LC_TELEPHONE=C
    > [11] LC_MEASUREMENT=en_GB.UTF-8 LC_IDENTIFICATION=C
    > attached base packages:
    > [1] stats graphics grDevices utils datasets methods base
    > loaded via a namespace (and not attached):
    > [1] compiler_4.1.2
    > If the Rscript executable is not found, then v.class.mlR cannot
    be run.
    >> Any help would be appreciated.
    >> - Daniel
    >> *[Message 1]*
    >> Running R now. Following output is R output.
    >> Traceback (most recent call last):
    >> File "/Users/dankozar/Library/ GRASS/8.0/Addons/scripts/v.
    class.mlR",
    >> line 977, in <module>
    >> main()
    class.mlR",
    >> line 908, in main
    >> subprocess.check_call(
    >> File
    >> "/Applications/GRASS-8.0.app/ <http://GRASS-8.0.app/&gt;
    >> line 368, in check_call
    >> retcode = call(*popenargs, **kwargs)
    >> File
    >> line 349, in call
    >> with Popen(*popenargs, **kwargs) as p:
    >> File
    >> line 951, in __init__
    >> self._execute_child(args, executable, preexec_fn, close_fds,
    >> File
    >> line 1821, in _execute_child
    >> raise child_exception_type(errno_ num, err_msg, err_filename)
    >> FileNotFoundError: [Errno 2] No such file or directory: 'Rscript'
    >> *[Message 2]*
    >> Details: <[Errno 1] Operation not permitted: 'v.class.mlR'>
    >> WARNING: Some addons failed when loading. Please consider to
    update
    >> your addons by running 'g.extension.all -f'.
    >> Thank you,
    >> Daniel Kozar
    >> PhD Candidate
    >> UC Davis - Hydrologic Sciences
    >> djkozar@ucdavis.edu
    >> (814) 380-6900
    >> ______________________________ _________________
    >> grass-user mailing list
    >> grass-user@lists.osgeo.org
    >> https://lists.osgeo.org/ mailman/listinfo/grass-user
    > Micha Silver
    > Ben Gurion Univ.
    > Sde Boker, Remote Sensing Lab
    > cell: +972-523-665918
    -- Thank you,
    Daniel Kozar
    Graduate Student
    djkozar@ucdavis.edu
    (814) 380-6900
    -- Thank you,
    Daniel Kozar
    Graduate Student
    djkozar@ucdavis.edu
    (814) 380-6900
Micha Silver
Ben Gurion Univ.
Thank you Micha,
This was the msg following “C:\Users\haarlooj\Documents> sessionInfo()”:
‘sessionInfo’ is not recognized as an internal or external command,
operable program or batch file.
I looked for the location and found this as location of R:
C:\Program Files\R\R-4.3.0\bin\x64
Location for Rstudio:
C:\Program Files\RStudio
Is it correct that I need to change the paths? What is the best method?
Best,
Jamille
On Sat, Jul 15, 2023 at 9:17 AM Micha Silver <tsvibar@gmail.com> wrote:
Hi Jamille
Dear all,
Windows 10.
window? i.e.
  • start grass (even without the GUI)
  • go to the command shell
  • run Rscript -e “sessionInfo()”
variables.
Best,
Jamille
pts[v.class.mlR.py](http://v.class.mlR.py) <http://v.class.mlR.py>”, line 977, in
main()
pts[v.class.mlR.py](http://v.class.mlR.py) <http://v.class.mlR.py>”, line 908, in main
368, in check_call
349, in call
951, in init
close_fds,
args,
file specified
Daniel,
issues like this.
Best,
Nicklas
Hi Micha,
around it.
this?
Thanks
Daniel
wrote:
Hi
Hi everyone,
1] (see
path
that the
permitted.
solve
(here’s what I get)
locale:
[1] compiler_4.1.2
be run.
  • Daniel
[Message 1]
class.mlR”,
line 977, in
main()
class.mlR”,
line 908, in main
File
“/Applications/GRASS-8.0.app/ <http://GRASS-8.0.app/>
File
line 349, in call
File
line 951, in init
File
[Message 2]
update
Thank you,
Daniel Kozar
PhD Candidate
djkozar@ucdavis.edu
(814) 380-6900
Micha Silver
Ben Gurion Univ.
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Micha Silver
Ben Gurion Univ.
On 17/07/2023 16:56, Jamille Haarloo wrote:
Thank you Micha,
What you need to try is:
The GRASS module v.class.mlR needs to be able to “find” the Rscript executable in order to run.
Best,
Jamille
Hi Jamille
Dear all,
Windows 10.
window? i.e.
variables.
Best,
Jamille
main()
368, in check_call
349, in call
951, in init
close_fds,
args,
file specified
Daniel,
issues like this.
Best,
Nicklas
Hi Micha,
around it.
this?
Thanks
Daniel
wrote:
Hi
Hi everyone,
1] (see
path
that the
permitted.
solve
(here’s what I get)
locale:
[1] compiler_4.1.2
be run.
  • Daniel
[Message 1]
class.mlR”,
line 977, in
main()
class.mlR”,
line 908, in main
File
File
line 349, in call
File
line 951, in init
File
[Message 2]
update
Thank you,
Daniel Kozar
PhD Candidate
djkozar@ucdavis.edu
(814) 380-6900
Micha Silver
Ben Gurion Univ.
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
ok, I misunderstood. I’m getting a similar response.
C:\Users\haarlooj\Documents>Rscript -e “sessionInfo()”
‘Rscript’ is not recognized as an internal or external command,
Thank you Micha,
Best,
Jamille
Hi Jamille
Dear all,
Windows 10.
window? i.e.
variables.
Best,
Jamille
main()
368, in check_call
349, in call
951, in init
close_fds,
args,
file specified
Daniel,
issues like this.
Best,
Nicklas
Hi Micha,
around it.
this?
Thanks
Daniel
wrote:
Hi
Hi everyone,
1] (see
path
that the
permitted.
solve
(here’s what I get)
locale:
[1] compiler_4.1.2
be run.
  • Daniel
[Message 1]
class.mlR”,
line 977, in
main()
class.mlR”,
line 908, in main
File
File
line 349, in call
File
line 951, in init
File
[Message 2]
update
Thank you,
Daniel Kozar
PhD Candidate
djkozar@ucdavis.edu
(814) 380-6900
Micha Silver
Ben Gurion Univ.
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Thank you,
Daniel Kozar
Graduate Student
djkozar@ucdavis.edu
(814) 380-6900
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
