Scott,
I have actually done some Perl scripting that does this automatically… not sure if that would help, and it is very coarse Perl, but it gets the job done. Example, I had about 500 ascii grids to import. Created a script that would get the list of the files, create the command r.in.arc for each of these, and then a separate script (which I could combine into one) to mosaic the rasters together. Actually, the Perl script created a shell script…
Is this the thought that you were onto?
Kevin Slover
Coastal / GIS Specialist
2872 Woodcock Blvd Suite 230
Atlanta GA 30341
(P) 678-530-0022
(F) 678-530-0044
From: grassuser-bounces@grass.itc.it [mailto:grassuser-bounces@grass.itc.it] On Behalf Of Sampson, David
Sent: Thursday, August 03, 2006 12:58 PM
To: Scott Mitchell
Cc: grassuser@grass.itc.it
Subject: RE: [GRASS-user] run commands sequentially - help please
Scott,
Thanks for the cleanup… now it is not so dirty
BTW I remember Markus showing us a way to save commands you type to the GRASS CLI into a script (think is was X.save where X=something)… this is good if you want to perform it once in geenral and then edit the script for variations. Couldn’t find it off hand in the docs.
I’d be interested to know if you could set and use variables in the approach we used bellow. I never tried. but if you could say use output=$OUTMAP and input=$INMAP and then you can loop for a series of maps. and the input and output are auto generated based on the basefile name.
Can someone provide a sample snippet of how this might look?
Would the for loop be part of the said script, or would you call one script from another passing variables?
This might be good if it is a repeated process you will use ALOT… a type of mild automation.
I notice that in grass 6.1 there is lots of information in the OUTPUT window of what is passed from the command… can you capture this?.. I have not tried any of the icons… if so then this is another way to maybe build your script. I’m likin 6.1 more and more
Just some thoughts.
Sent: August 3, 2006 12:47
To: Sampson, David
Cc: Tiago Salgueiro; grassuser@grass.itc.it
Subject: Re: [GRASS-user] run commands sequentially - help please
A few elaborations that might help unix-newbies:
On 3-Aug-06, at 12:25, Sampson, David wrote:
Dirty approach,
I used this approach when doing mass imports of files and only had slight variations.
under linux (shoudl work too in cygwin, dos batch would achieve the same thing)
I created a script file (executable text Basicaly) that for you would look like
for a script named runme.sh
#(what ever header you need for your shell)
#!/bin/sh
Putting $!/bin/sh at the top of a script will ensure that the file gets interpreted by whatever the default shell is on the system. Forcing other shells is also possible here, but using just “sh” means you get the default (i.e. as opposed to bash, csh, tcsh, ksh, etc etc).
v.in.asci (string of settings);
note that should be ascii with two i’s
g.region (string of settings);
v.surf.rst (string of settings);
nviz (string of settings);
#end of script
then at the $prompt you need to make the file executable
$chmod 777 runme.sh
Note this makes the file readable, writeable and executable to everyone on the system. If this is just your own private linux or windows box, you probably don’t care, but if someone is doing this on a multi-user system, you might not want other people to be able to edit your files. Using chmod 755 would make it readable and executable to anyone, but only writeable to you, the owner of the file. An alternative, more user-friendly syntax is
chmod u+x runme.sh
which simply says add the execute permission (“+x”) for the User (“u”) that owns runme.sh
then at the $prompt inside a GRASS session you can run the file
$./runme.sh
boom!
notice in the script that each line ends in a ; (semi-colon) this separates each command
I don’t think you need that. It’s C syntax to do that, not needed in a shell script unless you’re concatenating multiple commands on to a single line.
Note also that sometimes options need to be in quotes
eg
v.in.ascii option1=“settings string that may contain escape characters or spaces”;
Alternatively you can capture what you enter at the CLI using
From: grassuser-bounces@grass.itc.it [mailto:grassuser-bounces@grass.itc.it] On Behalf Of Tiago Salgueiro
Sent: August 3, 2006 11:24
To: grassuser@grass.itc.it
Subject: [GRASS-user] run commands sequentially - help please
First of all you should know that I’m a beginner using GRASS.
I want to create a 3D map from a text file with coordinates. I think the commands I will need are the following:
### 1 - v.in.ascii### 2 - g.region### 3 - v.surf.rst### 4 – nviz
But I don’t want to write the commands every time I want to see a map. So I desire to do this sequentially. How can I do that? This way I’ll only need to run one command and the map happens.
Thanks for your help.
Cumprimentos/Best Regards,
Tiago Salgueiro
grassuser mailing list
