I try to run GRASS73 within R (actually R-studio) using the rgrass7 library on MacOS 10.12.6. I followed the instructions stated in the wiki (https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7), however some of the commands were not working for me. For instance, “grass70 --config path” (also with grass73 etc) does not work here, however I found the path to the application which is: /Applications/GRASS-7.3.app; i.e. using “open /Applications/GRASS-7.3.app” opens my grass installation.
So I tried to initialize GRASS (North Carolina location - PERMANENT) from within R using the initGRASS() command:
initGRASS(gisBase = “/Applications/GRASS-7.3.app”, home = tempdir(),
gisDbase = “/Users/Johannes_Radinger/Documents/GRASS-GIS/”,
location = “nc_spm_08_grass7”, mapset = “PERMANENT”, SG=“elevation”,
override=TRUE)
However I get following error(s):
sh: g.gisenv: command not found
sh: g.version: command not found
Error in system(paste(“g.version”, get(“addEXE”, envir = .GRASS_CACHE), :
error in running command
So what I am doing wrong? Do I miss some arguments in my command or is this related to my Mac environment? Any suggestion I should try to solve that problem?
Thanks and best regards,
Johannes
Hi Rainer,
I used following commands and got following errors and output (using Rstudio). I also included now the output from sessionInfo() after loading “rgrass7”:
library(“rgrass7”)
Loading required package: sp
Loading required package: XML
GRASS GIS interface loaded with GRASS version: (GRASS not running)
Warning message:
package ‘XML’ was built under R version 3.4.1
#https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7
sessionInfo()
R version 3.4.0 (2017-04-21)
Platform: x86_64-apple-darwin15.6.0 (64-bit)
Running under: macOS Sierra 10.12.6
Matrix products: default
BLAS: /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
LAPACK: /Library/Frameworks/R.framework/Versions/3.4/Resources/lib/libRlapack.dylib
locale:
[1] en_US.UTF-8/en_US.UTF-8/en_US.UTF-8/C/en_US.UTF-8/en_US.UTF-8
attached base packages:
[1] stats graphics grDevices utils datasets methods base
other attached packages:
[1] rgrass7_0.1-9 XML_3.98-1.9 sp_1.2-4
loaded via a namespace (and not attached):
[1] minqa_1.2.4 MASS_7.3-47 compiler_3.4.0 Matrix_1.2-10 tools_3.4.0 Rcpp_0.12.11 splines_3.4.0
[8] nlme_3.1-131 grid_3.4.0 nloptr_1.0.4 lme4_1.1-13 lattice_0.20-35
initialisation and the use of North Carolina sample dataset
- gisDbase = “/Users/Johannes_Radinger/Documents/GRASS-GIS/”,
- location = “nc_spm_08_grass7”, mapset = “PERMANENT”, SG=“elevation”,
- override=TRUE)
On Thu, Sep 7, 2017 at 11:36 AM, Rainer Krug <rainer_krug@icloud.com> wrote:
Hi
How did you run these commands from R, which error did you get?
Could you provide a transcript of your errors?
Rainer
On 7 Sep 2017, at 10:04, Johannes Radinger <johannesradinger@gmail.com> wrote:
override=TRUE)
Johannes
grass-user mailing list
grass-user@lists.osgeo.org
Hi
The problem is the gisBase. it is the directory with the e.g. lib, bin directories. I am not using the GRASS App but installed from Home-brew, so I can’t help you there. Just look for general intro on how to use Grass in R on Mac.
Rainer
Hi
Rainer
override=TRUE)
Johannes
