Hi All,
I decided to try this program and downloaded the 6.0
version. I installed everything with success and were
able to run the data selection. Afterwards I
downloaded spearfish and unpacked it in the
home/<username>/datbase folder. I was able to select
the neccesary folders but when I press start grass,
the progra stops....
In the DOS window I received the following data:
Welcome to GRASS 6.0.0 (2005)
GRASS homepage:
http://grass.itc.it/
This version running thru: GNU Bash
(Cygwin) (/usr/bin/bash.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the graphical user interface
with: d.m &
When ready to quit enter: exit
GRASS 6.0.0 (spearfish57):~ > Error in startup script:
child process exited abnormally
while executing
"exec ps.map -p"
(procedure "DmPrint::init" line 14)
invoked from within
"DmPrint::init"
(procedure "main" line 32)
invoked from within
"main $argc $argv"
(file "/usr/local/grass6.0.0/etc/dm/d.m.tcl" line
894)
Can someone please help me???
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Hi
first of all, you should metion, that you are running GRASS on windows
using cygwin.
I allways used the 6.1 version on cygwin, it worked well. 6.0. is
becoming to be little bit outdated. After installing the 6.1 package,
version 6.0 should work too
jachym
On Wed, Jul 19, 2006 at 06:45:35AM -0700, jur ven wrote:
Hi All,
GRASS homepage:
with: d.m &
while executing
"exec ps.map -p"
invoked from within
"DmPrint::init"
invoked from within
"main $argc $argv"
894)
Do You Yahoo!?
grassuser mailing list
grassuser@grass.itc.it
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
I had the same experience as you. I tried to run GRASS 6.0 on Windows environment with Cygwin and I got the same error, after 4 days of trying different things, the easiest was to install the 6.1 version. Everthing worked perfeclty!!
Good luck!
MarÃa
To: jur ven <jurven007@yahoo.com>
CC: grassuser@grass.itc.it
Subject: Re: [GRASS-user] Running problems
Date: Wed, 19 Jul 2006 16:56:23 +0200
Hi
using cygwin.
jachym
> Hi All,
> GRASS homepage:
> with: d.m &
> while executing
> "exec ps.map -p"
> invoked from within
> "DmPrint::init"
> invoked from within
> "main $argc $argv"
> 894)
> Do You Yahoo!?
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
<< signature.asc >>
_________________________________________________________________
Moda para esta temporada. Ponte al dÃa de todas las tendencias. http://www.msn.es/Mujer/moda/default.asp
