How to run a python script in grass.
Thanks in advance,
nani.
Thanks in advance,
nani.
Hello,
the grass wiki will help you:
http://grass.osgeo.org/wiki/GRASS_and_Python
Soeren
2011/4/26 vinod kumar <nani.kunithi@gmail.com>:
Thanks in advance,
nani._______________________________________________
grass-user mailing list
grass-user@lists.osgeo.org
Hello
Put the script into the bin folder of your GRASS libary (the place where the add-ons are also stored)
Then you can start them in the Command Console of GRASS with
"scriptname.py", assuming that you've set the script options (#%) correctly.
/johannes
-------- Original-Nachricht --------
Datum: Tue, 26 Apr 2011 12:52:45 +0200
Von: Soeren Gebbert <soerengebbert@googlemail.com>
An: vinod kumar <nani.kunithi@gmail.com>
CC: grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] running Python script in grass
Hello,
http://grass.osgeo.org/wiki/GRASS_and_PythonCheers
Soeren2011/4/26 vinod kumar <nani.kunithi@gmail.com>:
> Hi all,
> Thanks in advance,
> nani.
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
Hi Johannes, Soeren Gebbert,
Thanks for the information. Is there any Editor so that i can easily write code.
nani
On Tue, Apr 26, 2011 at 1:01 PM, Johannes Radinger <JRadinger@gmx.at> wrote:
Hello
“scriptname.py”, assuming that you’ve set the script options (#%) correctly./johannes
Betreff: Re: [GRASS-user] running Python script in grassHello,
Thanks in advance,
nani.
http://lists.osgeo.org/mailman/listinfo/grass-user–
Just look at:
http://wiki.python.org/moin/PythonEditors
There are many!
I use Textwrangler on my Mac and before the
standard IDLE editor.
/johannes
Datum: Tue, 26 Apr 2011 13:10:48 +0200
Von: vinod kumar <nani.kunithi@gmail.com>
An: Johannes Radinger <JRadinger@gmx.at>
code.Thanks,
naniOn Tue, Apr 26, 2011 at 1:01 PM, Johannes Radinger <JRadinger@gmx.at>
wrote:> Hello
> correctly.
> /johannes
> > Hello,
> > Cheers
> > Soeren
> > > Hi all,
> > > Thanks in advance,
> > > nani.
GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
