Simple and stupid question. Can I run two instances of GRASS on a
machine on DIFERENT location and mapset?
I've been running r.watershed for 3 days now and I need to do some
stuff on another grass location but I'm afraid to mess up the
r.watershed process
Thanks
Daniel
Yes, you can.
Any software that allows you to mess up its own running processes
by starting it twice should be ashamed of calling itself modular.
I think GRASS is an example of a modular software that works
very well.
Daniel Victoria wrote:
r.watershed process
Thanks
Daniel
grass-user mailing list
grass-user@lists.osgeo.org
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
Hello Daniel,
I had no problem with this.. even at the same location but different mapset..
but I did not try it with long term running processes...
Greetings
Manuel
Daniel Victoria schrieb:
r.watershed process
Thanks
Daniel
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent Scientific Assistant
Physische Geographie Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften Geography/Geosciences
Universität Trier University of Trier
D - 54286 Trier
Tel.: +49-651-201 4557
Fax: +49-651-201 3976
Web: http://www-neu.uni-trier.de/index.php?id=9607
Hi Daniel!
I use grass 6.2.3 and 6.3.svn at the same time on different
location and mapset (of course!).
Nikos.
On Thu, 10 Jan 2008 12:10:23 -0200
"Daniel Victoria" <daniel.victoria@gmail.com> wrote:
GRASS on a
to do some
the
r.watershed process
Thanks
Daniel
Nikos Alexandris - Ph.D. Candidate
Department of Remote Sensing
and
Landscape Information Systems
(FeLIS)
Faculty of Forestry and Natural Environment
Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697
Fax. +49 (0) 761 203 3701
Skype: Nikos.Alexandris
Address: Tennenbacher str. 4
D-79106 Freiburg i. Br.
Germany
Indeed,
you can use the same location but different mapset!
On Thu, 10 Jan 2008 15:18:19 +0100
nikos.alexandris@felis.uni-freiburg.de wrote:
Hi Daniel!
different
Nikos.
> Hi,
> GRASS on a
> to do some
up
> the
> r.watershed process
> Thanks
> Daniel
Benjamin Ducke <benjamin.ducke@ufg.uni-kiel.de> writes:
> Yes, you can. Any software that allows you to mess up its own
> running processes by starting it twice should be ashamed of calling
> itself modular. I think GRASS is an example of a modular software
> that works very well.
BTW, it's one more reason to use WIND_OVERRIDE in one's modules
to temporarily switch to another region.
> r.watershed process
Yes, you can.
very well.
OTOH, being able to run multiple GRASS sessions concurrently is a
fairly recent feature, and it took a while to get that working.
Even using different mapsets, you still need to take care with reading
from a mapset which is being modified by another session (i.e. don't
try to read files which the other session might be writing to).
