[GRASS-user] Runtime error! / Program: C:\Osgeo4w\bin\python.exe
Dear friend,
I am compiling and installing grass on windows.
But getting error as follows.
Runtime error!
R6034
An application has made an attempt to load the c runtime library incorrectly.
Please help me how can i resolve the issues.
regards.
Sandip
Hello,
after a quick google-search: It seems an Error related to
the MSVCR80.DLL. AFAIK this .dll comes
with the libtiff via the osgeo4w setup. Which version of
libtiff do you have installed (check in the osgeo4w advanced
setup)?
But maybe some others have any other idea!?
/Johannes
-------- Original-Nachricht --------
Datum: Mon, 28 Nov 2011 15:49:14 +0530
Von: Sandip Maity <sandip.stesalit@gmail.com>
An: grass-user@lists.osgeo.org
Betreff: [GRASS-user] Runtime error! / Program: C:\\Osgeo4w\\bin\\python.exe
Dear friend,
Runtime error!
R6034
incorrectly.
regards.
Sandip
NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
Jetzt informieren: http://www.gmx.net/de/go/freephone
Dear Johannes,
I have installed libtiff 4.0.0dev-91 via osgeo4w setup.
Please suggest the way.
Regards.
Sandip
On Mon, Nov 28, 2011 at 4:42 PM, Johannes Radinger <JRadinger@gmx.at> wrote:
Hello,
setup)?
/Johannes
Betreff: [GRASS-user] Runtime error! / Program: C:\Osgeo4w\bin\python.exe
Dear friend,
Runtime error!
R6034
incorrectly.
regards.
Sandip
please choose libtiff 4.0.0dev-90
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Runtime-error-Program-C-Osgeo4w-bin-python-exe-tp7038211p7038597.html
Maybe that is causing the problem (as it did in my case!)
Via the advanced setup you can you can choose 4.0.0dev-90.
This works in my case. But you have to be careful then
with the make (the one you installed manually) this can be
updated and overwritten by the osgeo4w setup with the old version
3.7 again.
In that case you have to set to libtiff 4.0.0dev-90 and after that you have to copy again the new GNU make files (v3.81) into the directory
(as you already did according to the wiki)
Maybe we have to make that clearer in the wiki or do changes in
the osgeo4w setup to overcome the complicated and somehow interfering
installation of make3.81 and libtiff 4.0.0dev-90.
/Johannes
Datum: Mon, 28 Nov 2011 17:54:07 +0530
An: Johannes Radinger <JRadinger@gmx.at>
CC: grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] Runtime error! / Program: C:\\Osgeo4w\\bin\\python.exe
Dear Johannes,
Regards.
Sandip
wrote:
> Hello,
> setup)?
> /Johannes
> > Dear friend,
> > Runtime error!
> > R6034
> > incorrectly.
> > regards.
> > Sandip
Datum: Mon, 28 Nov 2011 04:49:55 -0800 (PST)
Von: Helmut Kudrnovsky <hellik@web.de>
Betreff: [GRASS-user] Re: Runtime error! / Program: C:\\Osgeo4w\\bin\\python.exe
ohh saw that to late that you posted already the answer!
Helmut
grass-user mailing list
Hi johannes and all,
According to your suggestion, I uninstall the libtiff- 4.0.0dev 91 and install libtiff 90. Also I have update make directory according to your direction.
Make -version showing 3.81.
But Still same error is coming.
Please reply sap.
Regards.
Sandip
On Mon, Nov 28, 2011 at 7:23 PM, Johannes Radinger <JRadinger@gmx.at> wrote:
3.7 again.
/Johannes
Betreff: Re: [GRASS-user] Runtime error! / Program: C:\Osgeo4w\bin\python.exe
Dear Johannes,
Regards.
Sandip
wrote:
Hello,
setup)?
/Johannes
Dear friend,
Runtime error!
R6034
incorrectly.
regards.
Sandip
Dear all,
I have a student of an on-line course that wants to use WinGRASS6.4.2RC2 on Windows XP but she can’t start the program. She has installed grass6.4.2rc2 under a Windows XP OS and the installation process seems to be ok («she gets the message Completed»). Now, she has two icons in her desktop (GRASS6.4.2RC2 & GRASS6.4.2RC2 with MSYS) but when she does a double clic over any of them, nothing happens. There is no error message but nothing is displayed. GRASS doesn’t starts…
Any suggestion?
I can’t reproduce that behaviour because I run an Ubuntu but I’ve tried to install wingrass on windows vista, and windows 7 in another pc, and it works ok, I do not experience any problem.
How can I help her?
Thanks in advance.
Lluís
for installing wingrass in winxp, try right click on the installer and
choose "run as admin".
if you don't install as admin, you don't have the permission to write in
"C:\Program Files".
HTH
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Runtime-error-Program-C-Osgeo4w-bin-python-exe-tp7038211p7042380.html
