[GRASS-user] sampling points in a grid
I have a vector of points. According to a regular grid, I need to (randomly) sample a certain number n of these points in each cell of the grid. Such number n is given in a column of the attribute table of the grid. How would you do this?
I have half idea to play with the coordinates and Monte Carlo, but I have the feeling that I’m not thinking GIS and there must be a easier way.
Thank you for any hint
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
Margherita,
Actually, my approach with be little changed either way; without know of a better GRASS-only approach, the kind of thing I have done is to:
(1) write-out to a text file for all grids x, y, value
(2) index the lines, producing, id, x, y, value
(3) in R randomly sample the index
(4) from (3) you have id, x, y, value for the random sample
(5) import (4) into grass using v.in.ascii
This will take a little scripting…
Best,
Tom
On Tue, Feb 17, 2015 at 8:49 AM, Margherita Di Leo <diregola@gmail.com> wrote:
Best regards,
Via Fermi, 2749
grass-user mailing list
grass-user@lists.osgeo.org
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
On Tue, Feb 17, 2015 at 4:49 PM, Margherita Di Leo <diregola@gmail.com> wrote:
you do this?
With a small script this should be doable:
- generate the grid as polygons (v.mkgrid)
- loop over each polygon
     - fetch category number or v.extract
     - fetch corresponding number of points to be created from DB
     - v.random, using the current grid polygon for restricted creation feature
        http://grass.osgeo.org/grass70/manuals/v.random.html#restriction-to-vector-areas
     - save point map
- patch all point maps into single resulting map
- remove single point maps
Something like this...
wrote:
> Hi,
(randomly)
would
> you do this?
feature
Here lies the problem. I need to randomly pick points that are already
existing. Example: for grid cell that has ID 42, I have 50 points, and have
to randomly pick 7 out of these 50.
     - save point map
Best regards,
Via Fermi, 2749
Maybe you can use a database selection approach for example in sqlite.
First update your points with your grid cell ID and then randomly select
7 rows from the selection where the grid cell ID == 42.
In sqlite there exists the function random(). Here you can find
an approach to select random rows from a sqlite table:
http://stackoverflow.com/questions/2279706/select-random-row-from-an-sqlite-table
I have not tested that approach, but maybe worth a try…
/Johannes
On Wed, Feb 18, 2015 at 11:55 AM, Margherita Di Leo <diregola@gmail.com> wrote:
you do this?
Here lies the problem. I need to randomly pick points that are already existing. Example: for grid cell that has ID 42, I have 50 points, and have to randomly pick 7 out of these 50.
  • save point map
  • patch all point maps into single resulting map
  • remove single point maps
Something like this…
Best regards,
Via Fermi, 2749
