Hi
Is it possible with grass to estimate the percentage of landscaped area in a city/waterhed by using satellite imagery processing.
if so, as a next step, is it also possible to differentiate between roads and and other impervious areas?
Hi
On Sat, Nov 24, 2018 at 2:48 PM Francois Chartier
<fra.chartier@gmail.com> wrote:
Hi
we did something similar with aerial imagery which we presented at the
last FOSSGIS 2018 in March:
There will be other examples as well.
Quite interesting for you will be the Sentinel Copernicus data. There
is also a related "Copernicus Land Monitoring Service", High
Resolution Layer Imperviousness:
https://land.copernicus.eu/pan-european/high-resolution-layers/imperviousness
For its "Product Specifications", see
https://land.copernicus.eu/user-corner/technical-library/hrl-imperviousness-technical-document-prod-2015
Best
