[GRASS-user] Saving NVIZ image in GRASS 7: changing image dimensions is only possible through manually resizing display window
Something I noticed in trying to save an NVIZ image in GRASS 7 (Version:
57592)
In order to save a larger resolution image file, it is necessary to manually
resize the display window.
Only a portion of the image is saved after clicking on the NVIZ display icon
- 'Save display to graphic file' - and inserting new image dimensions or
selecting a template.
Richard
System:
GRASS 7 / Mint Linux 13 (Ubuntu Precise)
<http://osgeo-org.1560.x6.nabble.com/file/n5076708/image_nviz_8sept2013.jpg&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/Saving-NVIZ-image-in-GRASS-7-changing-image-dimensions-is-only-possible-through-manually-resizing-diw-tp5076708.html
could you please create a ticket, I cannot fix this easily and I don’t want to forget about it.
Thank you,
Anna
On Sun, Sep 8, 2013 at 9:37 AM, RichardC <richtcooper@hotmail.com> wrote:
57592)
  • ‘Save display to graphic file’ - and inserting new image dimensions or
Richard
System:
<http://osgeo-org.1560.x6.nabble.com/file/n5076708/image_nviz_8sept2013.jpg>
grass-user mailing list
grass-user@lists.osgeo.org
Ticket at http://trac.osgeo.org/grass/ticket/2070
Best,
Richard
View this message in context: http://osgeo-org.1560.x6.nabble.com/Saving-NVIZ-image-in-GRASS-7-changing-image-dimensions-is-only-possible-through-manually-resizing-diw-tp5076708p5076767.html
