[GRASS-user] Scalebar for lon/lat projection in ps.map
I am preparing a country-wide map using ps.map. The region spans 2-3
UTM zones although most of the region is covered by one zone but I
still need the data at the fringes covered in another zone. In order
to do that I used a lon/lat projection. However, ps.map will not
produce a scalebar for lon/lat projection for good reasons.
I know this isn't good practice. Any Ideas how I can produce a
"scalebar" for lon/lat?
cheers,
maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
You could change the projection to Plate Carée (aka Equidistant
Cylindrical), which is essentially just lat/lon with scale factors.
Also, there's no fundamental reason why you can't use UTM for data
which doesn't fit within a single zone (obviously, if you have data in
other UTM zones, you'll have to reproject it, but that's no worse than
reprojecting to lat/lon).
In order to do that I used a lon/lat projection. However, ps.map
will not produce a scalebar for lon/lat projection for good reasons.
produce a "scalebar" for lon/lat?
my advice is: don't. overlay a grid or geogrid instead. with at least
two grid lines for both lat + long the reader can see the scale.
you can reproject everything into the central UTM zone, but the outside parts may start to be distorted. if only going +/- 1 zone you may get away with it.
Hamish
Thanks!
with it.
I followed this advice and used a central UTM zone.
Hamish
| _)_/LI
