[GRASS-user] Scatter plot cannot be added
Hello guys,
I have MODIS data. It is sixteen bit unsigned integer. When I want to add scatter plot, there is a warning :
"Scatter plot cannot be added.
Multiple of bands ranges <x53.1@PERMANENT:65529 * x53.1@PERMANENT:65529 = 4294049841 > is higher than maximum limit <16810000> "
So, how to make big maximum limit on Grass GIS, so that I can add scatter plot of MODIS data?
mega
On 12/23/20 5:09 AM, mega saputra wrote:
Hello guys,
Please post your computation region (i.e. the output of g.region -p) and the command you used.
mega
grass-user mailing list
grass-user@lists.osgeo.org
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Sorry, there is holiday.
I import the raster. Then set the region. This is my syntax :
g.region -up raster=rgb.1
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
(Sat Dec 26 05:24:05 2020) Command finished (0 sec)
Then, from menu Imagery > Classify image > Interactive input for supervised classification. Then the output is like this :
G__open(read): Unable to open ‘/home/mega/newLocation/PERMAN
ENT/.tmp/mega/vector/trAreas114130/frmt’: No such file or
directory
I don’t know why there is that message.
Then in Plots Menu, I choose Scatter Plots. I click Add scatter plot. In the Name of imagery group, I choose the raster. In the Name of imagery subgroup, I type the name. I click Create/edit group. In x and y axis, I choose a band. I click Add. Then there is a message that :
In this case, I have defined the region. Thank you for your attention.
mega
Hello guys,
<16810000> "
mega
Micha Silver
Ben Gurion Univ.
The "-u" flag does not set the current computational region to your raster. It just reports what would happen if you do reset the region.
Please try:
g.region -ap rast=rgb.1
and report back the output.
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
G__open(read): Unable to open '/home/mega/newLocation/PERMAN
ENT/.tmp/mega/vector/trAreas114130/frmt': No such file or
directory
I don't know why there is that message.
mega
On Wed, Dec 23, 2020 at 4:30 PM Micha Silver <tsvibar@gmail.com <mailto:tsvibar@gmail.com>> wrote:
    > Hello guys,
    > I have MODIS data. It is sixteen bit unsigned integer. When I
    want to
    > add scatter plot, there is a warning :
    > "Scatter plot cannot be added.
    > Multiple of bands ranges <x53.1@PERMANENT:65529 *
    > x53.1@PERMANENT:65529 = 4294049841 > is higher than maximum limit
    > <16810000> "
    -p) and
    > So, how to make big maximum limit on Grass GIS, so that I can add
    > scatter plot of MODIS data?
    > Regards,
    > mega
    > grass-user mailing list
    > grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
    > https://lists.osgeo.org/mailman/listinfo/grass-user
    <https://lists.osgeo.org/mailman/listinfo/grass-user&gt;
    -- Micha Silver
    Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
The result is the same. It cannot add scatterplot.
Here is the output :
(Sun Dec 27 05:20:25 2020)
g.region -ap raster=rgb.1
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
(Sun Dec 27 05:20:25 2020) Command finished (0 sec)
ENT/.tmp/mega/vector/trAreas54950/frmt’: No such file or
directory
If you want to try my data, my data is in : https://1drv.ms/u/s!AjXAWS5maHffhyH0q9oTos1umy3D?e=bKa7mX
Thank you.
regards,
mega
The “-u” flag does not set the current computational region to your
Please try:
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
directory
<16810000> "
mega
Hello guys,
want to
<16810000> "
-p) and
mega
grass-user@lists.osgeo.org mailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
<https://lists.osgeo.org/mailman/listinfo/grass-user>
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Here’s my attempt:
I downloaded the rgb.tif that you linked to, then used it to create a new, fresh location
Create a NEW location “mega” using the georeferenced rgb.tif file to define location
and import the file
Run at the command line, before starting grass:
grass78 -c rgb.tif /home/micha/grass/mega
Now at the grass prompt:
Check projection settings
g.proj -p
-PROJ_INFO-------------------------------------------------
datum : wgs84
ellps : wgs84
proj : ll
no_defs : defined
-PROJ_EPSG-------------------------------------------------
epsg : 4326
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
Install the scatterplot extension
g.extension r.scatterplot
Downloading precompiled GRASS Addons <r.scatterplot>…
Updating extensions metadata file…
Updating extension modules metadata file…
Installation of <r.scatterplot> successfully finished
Now run r.scatterplot on two bands
r.scatterplot input=rgb.3,rgb.2 output=scatter_3_2
100%
Building topology for vector map scatter_3_2@PERMANENT
Registering primitives…
11830000
Almost 12 million points (!)
The X-Y coordinates of the points are the scatterplot values.
HTH,
Micha
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
directory
Thank you.
regards,
mega
Please try:
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
directory
<16810000> "
mega
Hello guys,
want to
<16810000> "
-p) and
mega
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Remote Sensing Lab, Sde Boker
Ben Gurion University
g.proj -p
datum : wgs84
ellps : wgs84
proj : ll
no_defs : defined
epsg : 4326
unit : degree
units : degrees
meters : 1.0
(Mon Dec 28 07:25:33 2020) Command finished (0 sec)
(Mon Dec 28 07:25:42 2020)
Fetching <r.scatterplot> from GRASS GIS Addons repository (be patient)…
Compiling…
Installing…
Updating addons metadata file…
(Mon Dec 28 07:25:50 2020) Command finished (7 sec)
(Mon Dec 28 07:26:18 2020)
r.scatterplot input=rgb.1,rgb.3 output=scatter_1_3
Building topology for vector map scatter_1_3@PERMANENT
(Mon Dec 28 07:28:40 2020) Command finished (2 min 21 sec)
(Mon Dec 28 07:30:53 2020)
v.info map=scatter_1_3@PERMANENT
| Mapset: PERMANENT |
| Database: /home/mega |
| Title: |
| Map scale: 1:1 |
| Name of creator: mega |
| Organization: |
| Source date: Mon Dec 28 07:26:19 2020 |
Timestamp (first layer): none
Map format: native
Type of map: vector (level: 2)
Number of points: 11836384 Number of centroids: 0
Number of lines: 0 Number of boundaries: 0
Number of areas: 0 Number of islands: 0
Number of faces: 0 Number of kernels: 0
Number of volumes: 0 Number of holes: 0
Map is 3D: Yes
Number of dblinks: 0
Projection: Latitude-Longitude
N: 65528N S: 0
E: 65528E W: 0
B: 0 T: 0
Digitization threshold: 0
Comment:
(Mon Dec 28 07:30:53 2020) Command finished (0 sec)
But, there is no scatter plot in Map Display. Then I click twice in vector > scatter_1_3 in Data tab. Then there is a message :
“Unable to zoom to vector map scatter_1_3@PERMANENT
Details: Illegal latitude for North: 65528”
How to solve the problem?
mega
On Sun, Dec 27, 2020 at 3:22 PM Micha Silver <tsvibar@gmail.com> wrote:
Here’s my attempt:
and import the file
g.proj -p
datum : wgs84
ellps : wgs84
proj : ll
no_defs : defined
epsg : 4326
unit : degree
units : degrees
meters : 1.0
100%
11830000
HTH,
Micha
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
directory
Thank you.
regards,
mega
Please try:
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
directory
<16810000> "
mega
Hello guys,
want to
<16810000> "
-p) and
mega
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Finally, I succeed to display scatter plot. I display scatter plot from Map Display > Create bivariate scatterplot of raster maps. Then I choose two band. You see in the attachment.
But, in this scatter plot, I can not create a polygon like in https://grass.osgeo.org/grass78/manuals/wxGUI.iscatt.html.
I want to create region of interest in the scatter plot link with the raster like in the website page.
Creating scatter plot from the website page will return error. It is about maximum limit.
How to solve this?
mega
g.proj -p
datum : wgs84
ellps : wgs84
proj : ll
no_defs : defined
epsg : 4326
unit : degree
units : degrees
meters : 1.0
Compiling…
Installing…
| Mapset: PERMANENT |
| Title: |
| Map scale: 1:1 |
| Organization: |
Map format: native
Map is 3D: Yes
N: 65528N S: 0
E: 65528E W: 0
B: 0 T: 0
Comment:
mega
Here’s my attempt:
and import the file
g.proj -p
datum : wgs84
ellps : wgs84
proj : ll
no_defs : defined
epsg : 4326
unit : degree
units : degrees
meters : 1.0
100%
11830000
HTH,
Micha
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
directory
Thank you.
regards,
mega
Please try:
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
directory
<16810000> "
mega
Hello guys,
want to
<16810000> "
-p) and
mega
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
(attachments)
g.proj -p
Yes, that’s correct. You need to understand how r.scatterplot works. The X-Y coordinates in the newly created point vector layer are the raster values at each pixel of the original rasters. In this case, since the original are color bands, the values represent reflectance for each band. These values can go as high as 65528, which is way beyond the range in a latitude/longitude coordinate system (maximum long/lat of 360 X 180).
If you want to carry on with this (in your next mail you are beginning with the interactive scatter plot), it might be helpful to export the X-Y “coordinates” to a text file for plotting in some other software. Just keep in mind that you will get a list of 12,000,000 rows with two columns of numbers-the reflectances of both bands.
mega
Here’s my attempt:
and import the file
g.proj -p
datum : wgs84
ellps : wgs84
proj : ll
no_defs : defined
epsg : 4326
unit : degree
units : degrees
meters : 1.0
100%
11830000
HTH,
Micha
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
directory
Thank you.
regards,
mega
Please try:
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
directory
<16810000> "
mega
Hello guys,
want to
<16810000> "
-p) and
mega
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Micha Silver
I guess Grass GIS can create interactive scatter plot from my data. Because, in other menu on Grass GIS (not in interactive scatter plot), it can create a scatter plot.
I will post new email in new title as your suggestion about interactive scatter plot.
Thank you for your response.
mega
g.proj -p
mega
Here’s my attempt:
and import the file
g.proj -p
datum : wgs84
ellps : wgs84
proj : ll
no_defs : defined
epsg : 4326
unit : degree
units : degrees
meters : 1.0
100%
11830000
HTH,
Micha
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
directory
Thank you.
regards,
mega
Please try:
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 13:07:42.9N
south: 27:38:15.5S
west: 100:55:15.7E
east: 131:15:38.1E
nsres: 0:00:36.8
ewres: 0:00:36.8
rows: 3988
cols: 2968
cells: 11836384
directory
<16810000> "
mega
Hello guys,
want to
<16810000> "
-p) and
mega
Micha Silver
Ben Gurion Univ.
Micha Silver
Ben Gurion Univ.
Micha Silver
Micha Silver
