Gabriele N. wrote:
All my scripts in bash work with tcltk.
Now, I take as example my 2 scripts: v.to.dem.sh and v.impact.sh.
With WxPython all the scripts were not working with grass 63. With Grass64,
instead, some scripts works (es v.impact.sh) and some other scripts does not
works (es.v.to.dem.sh). But I do not know what may be the characteristic
that makes v.impact.sh work and that does not work v.to.dem.sh.
I hope to have been clearer.
Thanks
Gabriele
PS
The error is always the same. Here's an example:
GRASS 6.4.svn (gb2):~ > v.to.dem.sh
File "/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/menuform.py", line 1687, in <module>
GrassGUIApp( grassTask( sys.argv[1] ) ).MainLoop()
File "/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/menuform.py", line 193, in __init__
xml.sax.parseString( getInterfaceDescription( grassModule ) , processTask( self ) )
File "/usr/lib/python2.5/xml/sax/__init__.py", line 49, in parseString
parser.parse(inpsrc)
File "/usr/lib/python2.5/xml/sax/expatreader.py", line 107, in parse
xmlreader.IncrementalParser.parse(self, source)
File "/usr/lib/python2.5/xml/sax/xmlreader.py", line 123, in parse
self.feed(buffer)
File "/usr/lib/python2.5/xml/sax/expatreader.py", line 211, in feed
self._err_handler.fatalError(exc)
File "/usr/lib/python2.5/xml/sax/handler.py", line 38, in fatalError
raise exception
xml.sax._exceptions.SAXParseException: <unknown>:21:73: not well-formed
(invalid token)
This indicates the the output from
v.to.dem.sh --interface-description
isn't valid XML.
This is likely to be caused by the contents of the option descriptions
at the top of the script (the #% lines).
Does one of the entries have <unknown> as its value? If so, which
field (gisprompt, label, etc) is it in?
I suspect that the code which generates the XML data isn't always
converting <, > and & to <, > and & when it should.
You can work around the problem by using e.g. (unknown), but we should
really fix this in the code which generates the XML.
