Hi everybody,
I want to select areas that don’t overlap with points, using “v.select -r […] operator=overlap”, I get unclosed boundaries and centroids at the places where an area is neighbour of a selected area. I do not understand how to obtain also the common border so to obtain closed boundaries with centroids (areas). I’m using GRASS 6.4, and imported the map of areas from a shapefile…
Thanks, and sorry for the simple question.
Daniel
Hello Daniel,
What about using operator=contains and -r flag? Does that work?
You may also want to update to GRASS 7. Check the manual for v.select [0] there, it has been improved a lot with examples for most (if not all) operators
Best,
Vero
[0] https://grass.osgeo.org/grass70/manuals/v.select.html
2016-03-19 5:39 GMT-03:00 Daniel Torres <nobeeakon@gmail.com>:
Hi everybody,
Daniel
grass-user mailing list
grass-user@lists.osgeo.org
Thanks for the answer Veronica, sadly it didn’t worked. As far as I understand, using v.select with the flag -r , selects the common boundary first, so it is the excluded when in the reverse selection is done, don’t understand how exactly to solve that using only v.select. Instead I v.select(ed) -r , then v.extract centroids, and finally v.select areas that overlap with centroids.
Meanwhile waiting for the beautiful GRASS 7 for Debian.
Thanks again, and nice day.
Daniel
On Sat, Mar 19, 2016 at 3:07 PM, Veronica Andreo <veroandreo@gmail.com> wrote:
Hello Daniel,
Best,
Vero
Hi everybody,
Daniel
On 20/03/16 06:10, Daniel Torres wrote:
Thanks for the answer Veronica, sadly it didn't worked. As far as I
done, don't understand how exactly to solve that using only v.select.
I don't really understand why there are "common boundaries" between points and areas ? Could you provide a reproducible example, using the NC demo data, so that we can understand what exactly is the issue ?
Moritz
On Sat, Mar 19, 2016 at 9:39 AM, Daniel Torres <nobeeakon@gmail.com> wrote:
Hi everybody,
I want to select areas that don't overlap with points, using "v.select -r
[...] operator=overlap", I get unclosed boundaries and centroids at the
centroids (areas). I'm using GRASS 6.4, and imported the map of areas from a
shapefile...
I could reproduce this: all boundaries of areas that overlap with
points are not written to the output when using v.select -r. This
caused unclosed boundaries of neighboring unselected areas. Fixed in
trunk r68110 and relbr70 r68111. You will need to wait for GRASS 7.0.4
or compile GRASS 7 yourself (easy on Debian).
That was not at all a simple question, thanks for reporting the problem!
Markus M
