[GRASS-user] select features which are completely within a polygon
Hello list,
someone know how to select features (lines) which are completely within a polygon layer?
I have one layer two layers, one with the country boundary (i.e. USA) and another with the states boundaries (i.e. USA states Alabama, Arizon, etc.). The original data are polygon features. Since i need only the boundaries I have processed the layers and converted them into line features.
The problem appears when I try to remove the common boundaries (country-state). So I need only the inner states boundaries. So I have tried to select, with v.select, the lines (boundaries) which are completely within the country (polygon), without the common country boundary. I have tried as well with v.overlay (xor). But without positive results.
Can someone help me?
Thanks
Manuel
On 29/05/08 21:49, Manuel Sangiao wrote:
Hello list,
Just brainstorming: You might be able to do something with a combination of v.to.points (country boundaries) and v.distance (from points to state boundary lines) to identify the state boundary lines that you would like to delete, then use v.edit to identify line ids based on cats, then to delete those lines based on their line id.
But haven't thought about it long enough to be sure it works.
Moritz
