I’d like to create from an existing GRASS vector map that has 3 layers (with three attribute tables) a new vector map that has only one layer and its associated attribute table (here the information related to layer 3).
What I am doing so far (in python):
First copy the map to a new one and copy table (that of layer 3)
that I want to re-connect to new map
grass.run_command(“g.copy”,
overwrite=True,
vector=“oldmap,newmap”)
grass.run_command(“db.copy”,
overwrite=True,
from_table=“table_layer3”,
to_table=“table_layer3_copy”)
Second delete all tables of the newmap
for i in [1,2,3]:
grass.run_command(“v.db.droptable”,
flags=“f”,
map=“newmap”,
layer=i)
Third reconnect a table to the newmap
grass.run_command(“v.db.connect”,
overwrite=True,
map=“newmap”,
When I check in the attribute table manager, there is only one layer listed (layer 1).
Similarly, v.db.connect reports:
v.db.connect -p map=newmap
Vector map is connected by layer <1/table_layer3_copy> table <table_layer3_copy> in database […]
However, in d.vect I can still select from all three layers that were in the old map (-1,1,2,3),
and all of them can be displayed (with -1 specified)?
So does may newmap have three layers or only one?
How can I make the third layer the default layer 1 and remove all other layers?
Or is there a way to copy a vector map with just a single layer and its associated table specified as default?
Thank you very much!
/Johannes
