[GRASS-user] select the map that does not match a string
Hello,
I wonder how to filter the select box (with Shift-Ctrl-L) or the data tab display, to maps do not match with a string. for exemple “myraster.*^(?!unwanted_string)” should display all maps beginning with “myraster” and without “unwanted_string”
This does not work. Is there any trick ??
Thank you for your advice
Frank
