I have used the r.los function to calculate the viewshed from a point in the
map. The result is a subset of a circle around that point. Now, I want to
select a sector of this circle which has an angle of 45 (or whatever), and
nullify the rest of the circle. Any idea on what is the best way to do that?
Thanks in advance,
Ahmad
View this message in context: http://n2.nabble.com/Selecting-a-sector-of-the-viewshed-tp4907825p4907825.html
Well, I think it wasn't that hard anyway. Here is how I did it. First, you
should calculate the angle of each point with respect to the center of the
circle (the observer's position). Then you can select those points which
reside in the wanted range.
grass.mapcalc("${temp} = if(isnull(${temp1}), null(), if(
atan(x()-${i0},y()-${i1}) < ${low} || atan(x()-${i0},y()-${i1}) > ${high},
null(), ${temp}))",
temp = map,
low = low_angle_range,
high = high_angle_range,
i0 = areawest+position[0],
i1 = areasouth+position[1])
View this message in context: http://n2.nabble.com/Selecting-a-sector-of-the-viewshed-tp4907825p4910614.html
