I am new to grass, but not GIS (I was trained in ArcGIS in collage a year or so ago.) I feel like what I am trying to do is simple, yet I am not having any luck.
I have two vector maps, one of zipcodes in New York State, and one of New York counties. The goal is to have a map of New York City by zipcode. I was going to select the New York City counties that are NYC (the fine folks at the NYS gis repository already have this as a category in the County file.) Unfortunately, I cannot get past the first step. Trying to use the SQL query from the “GIS Attribute Table Manager” causes GRASS to crash (I’m using windows GRASS.) Using the selection option from d.vect causes it to display nothing. I’m not certain about the proper syntax for the SQL query, but I have tried all the obvious options. the field is called NYS and is Y/N. So as far as I can tell, the SQL query should be something like NYS = Y or NYS = “Y”
Do I need to install SQL under windows to have the SQL queries work? It doesn’t look like it as far as I can tell from the documentation. am I missing something with the SQL query? Is this a known bug?
On Fri, Oct 25, 2013 at 8:37 PM, Christopher Schroeder
any luck.
So let's hope to improve that
SQL query from the "GIS Attribute Table Manager" causes GRASS to crash (I'm
Well, "this should not happen". Which version do you use exactly?
And this query?
display nothing. I'm not certain about the proper syntax for the SQL query,
Y or NYS = "Y"
